Sir help me
Good day to all you sir, i ahve a problem regarding my cpu. if i turns on it will never go windows. then, noted,cd booth. and ntldr is missing. sir,, where can i find that NTLDR located? hope you will help, thanks its me mac from phillipines.
You need re-right your ntlrd here's the instruction
you have to boot into recovery console.
Boot off windows CD, press "r" to access console, enter the following command.
copy d:\i386\ntldr c:\
copy d:\i386\ntdetect.com c:\
Posted on Nov 13, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
there an error in your operating system
that the compputer cannot read in your hardisk
is the only way for that is to reformat your hard drive!!!
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
What is NTLDR error sir?
NTLDR (abbreviation of NT Loader) is the boot loader for all releases of Microsoft's Windows NT operating system up to and including Windows XP and Windows Server 2003. NTLDR is typically run from the primary hard disk drive, but it can also run from portable storage devices such as a CD-ROM, USB flash drive, or floppy disk. NTLDR can also load a non NT-based operating system given the appropriate boot sector in a file.
NTLDR requires, at the minimum, the following two files to be on the system volume:
  • NTLDR, which contains the main Boot loader itself
  • boot.ini, which contains configuration options for a boot menu.
This error means that NTLDR is missing somehow from your computer,hard disk problem,virus.etc
You can go to that page and follow the instructions exacty as he says and your problem will gone:)
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 12, 2010 | Abit KW7 Motherboard
NTLDR is missing error on starting the machine
When a PC system or notebook displays NTLDR is missing you can still recover with out re-installing windows. Follow the instructions on the link provided; http://www.computerhope.com/issues/ch000465.htm
Scroll down to: Corrupt NTLDR and/or NTDETECT.COM file.
The fix is a bit different for Win 2000 &Win XP.
Mike
Oct 17, 2009 | Systemax Neotach 3300 Notebook
NTLDR IS MISSING IN Every 2 to 3 dyas
Boot using your origanal Operating system CD, Press "R" at the first screen where it gives you an option...type fixboot, then type "Y"
If this doesn't work do exactlly the same but instead of fixboot, type fixmbr, follow the steps, and say yes wherever it ask you ,,
good luck let me know if you are still struggeling...
Cheers
May 25, 2009 | Microsoft Windows XP Professional SP2
Ntldr is missing
Often this problem indicates a probable memory fault and/or a corrupt NTLDR file in the root directory of the main drive. Possible corrective action would be:
  • clean/replace memory;
  • remove HD, attach to a 2nd PC and simply copy/paste NTLDR file;
  • re-install/repair Windows using a recovery CD.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 08, 2008 | Computers & Internet
No post/blank screen
Do you have your Windows XP CD? Boot from that CD and at the prompt, press r for repair.
select 1 for windows installation and at the prompt type the follwing and press enter:
chkdsk /r
once complete (will take some time), reboot and you should be back in action
May 02, 2008 | Compaq NX6110 TFT XGA Notebook
Ntldr
First check your bios & make sure it see's your hard drive & it's setup correctly. If it is there could can be other reasons for the missing NTLDR.
Suggest you take you Windows CD and boot to it. If your CD does not boot. Re-start the PC & start pressing the F8 key every two seconds. This will bring up a boot menue. Choose your cdrom drive.
Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy these two files to you Hd. copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Replace the drive letter listed above for your cdrom's drive letter.
Once copy has been complete re-boot your Pc.
If you still get missing NTLDR. Do a complete reinstall of windows. Your personal data should stay intact.
Please post back if this has not fixed missing NTLDR, there are more fix's that can be applied. I only listed the most common.
Feb 12, 2008 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
Ntldr is missing on my windows millennium pc
Here is a great guide explaining how to restore the NTLDR file.
Dec 30, 2007 | Microsoft Windows 2000 Professional for PC
What is NTLDR
NTLDR is short for New Technology Loader, an essential initializing program for Windows.NT4/2k/XP.
A missing NTLDR indicates several fault possibilities, most common are:
1. partially defective memory;
2. corrupt files or Windows installation in the boot hard disk; and/or
3. IDE cable, motherboard, the hard disk itself and others.
If it is a memory problem, try removing the memory sticks and clean the gold pins with a pencil eraser, re-install and make sure seated correctly. Reboot and try again.
If it is a corrupt file, insert an OEM Windows XP Installer (bootable) CD into the PC and when prompted, press any key to boot from CD. Once in the setup menu, press the "R" key to repair Windows. Log into by pressing "1" key and then enter.
You would need your administrator password, then hit enter. You need to copy the missing file(s) from the CD to your HD. Type :
copy D:\i386\ntldr C:\
copy D:\i386\ntdetect.com D:\
Soon as copied, reboot.
If thereafter, other files turn out to be missing also, perhaps you might be better off formatting your HD and re-installing your OS since chances are not only 1 or 2 files are already corrupt.
In some cases, even a re-install will not solve the problem, you then may either have to replace your memory or your hard disk.
Hope this be of some idea/help. Pls post back how things turn out or should you need additional information.
Nov 03, 2007 | Toshiba Satellite A15-S157 Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
