Question about Cell Phones
LCD loses the display and gets totally white after some continuous operation. when i slide up or down the slide, at a particular point, LCD loses the display and gets tatally white. I have Samsung SGH D-880. Thank You.
  • basit_ali02 Nov 13, 2008
    Please provide the slution. I had also contacted to "Mobile Zone" but they did not respond.
  • 199 Answers
Your problem is in the flex or ur ribon connected to your lcd from your phone, it is also near to some cases with fones that slides or flip
Posted on Nov 13, 2008
ERROR CODE 5100
This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out
Apr 24, 2013 | Canon PIXMA MX300 All-in-One Printer
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
My lcd screen is bright white and I cannot see anything, or do anything on my video camera. Is it totally wrecked?
Try resetting the Camcorder and check the operation. To reset the Camcorder, press the RESET button behind the LCD screen using a small pointed object.
Mar 05, 2012 | Sony DCR-SR47 Camcorder
My nokia N80 when i slide slider upward the LCD become white.i cannot type a message .
Most slide up phones usually having problem with the display,particularly the flex connector which connect the upper and lower panel,can also be a LCD problem when the phone experience dropping off the ground or damage by water,just visit any mobile service shop near for a complete diagnosis and troubleshooting.
Aug 27, 2011 | Cell Phones
I get message service error 5100
Error Code.........Description
5000 ...................Home position error
5100 ...................Carriage control error
5200 ...................Head temperature sensor error
5400 ...................Printer temperature sensor error
5600 ...................No cartridge error
5C00 ...................Purging operation error
5200 ...................Scanner cartridge error
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
good luck
Nov 29, 2010 | Canon Office Equipment & Supplies
My viewsonic vx2025wm 20.1 lcdmonitorgoes green,sometimesyellow,then returns towhite screen
check your cable connection if the color changes.. as normally bad or lose display connection will cause this problem..
but if it turn to total white without any image.. then most probably the LCD monitor is faulty..
but there are some cases when your display card that is giving this funny problem.. if it get too hot.. check your PC display card whether the cooling fan is turning or jam.. this is the main cause the display card get overheat and give you funny display...
May 23, 2010 | HP Computers & Internet
White display LCD TV
The screen glowinh white mean it is not getting voltage to the LCD controller, the ribbon cable may have come lose. You need to open it up and look inside.
See some pictures here: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Continual paper jam: canon mp830 - error 5100
follow the following:
Thanks
Mar 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
PB6100:No picture display
The projector needs to be turned on first, then connect it to the laptop. If the picture still does not show at that point, press the FN and the LCD keys on your laptop at the same time. This should work.
Feb 10, 2008 | BenQ PB6100 Multimedia Projector
Sony ericsson T610 blue/white screen error
that happend to my phone, i took out the battery and sim card then put it back in and it seemed to fix it.
Jan 28, 2008 | Sony Ericsson T610
Cell Phones Logo
59 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
