Need help hooking the right colored prong wires onto my sequencer
Can you guys please help me?? i had a sequencer to go bad on my electric furnace so i drew up a diagram of the what wires went to what prongs, bought the piece came back to hook it up and what happens i cant find my diagram anywhere now i am stuck with nine wires hanging out of my furnace with a brand new sequencer that i cant put them on and i can not afford a repairman due to being laid off. any help would be appreciated the same colored diagram as mine would be so helpful.. nordyne electric furnace E2EB-012HA getting cold in ky..
  • chadwick0211 Nov 20, 2008
    I'm having the same problem with no wiring diagram. I'm really stuck.
  • 96 Answers
There should be a wire diagram on the back side of the panel you took off to get to the sequencer
Posted on Nov 13, 2008
How do you hook up the thermostat to a Central Electric feh-017ha-04 furnace? Also, where do the A/C wires hook up to the furnace?
The standard color code for the HVAC is as follows....
Red=Hot or 24v
White=Heat
Green=Fan
Yellow=A/C
White 1=secondary heat.
Blue=Spare
Orange=Heat Pump
C=Common
The thermostat has the terminals marked R,Rh,W,G,Y.
The furnace should have a terminal strip with similar markings.
If you only have 1 control transformer this will be easy.
Hook the wires up using the colors I have listed. If you don't have the same color wires go with whats close to them....such as use Orange for Red etc. It really doesn't matter as long as they are landed on the same terminals on the thermostat and furnace. Two wires running to A.C unit outside put one on Y the other on C. If you need any more help let me know!
Jun 02, 2014 | Intertherm Heating & Cooling
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
I have a coleman evcon electric furnace. The blower fan runs constantly, the switch is in auto and the fans runs even when the thermostat is shut off.
Most likely on that particular electric furnace you have a fan sequencer that is closed (stuck shut). It is the black relay that you are looking at when you take off the furnace cover to access your heat strips. You should have a red wire coming from the blower motor that plugs into the side of it. If you have a ohm meter turn power off and remove wire. Check resistance across the sequencer and it should read OL. If you have resistance across it, the relay is bad. Replace it.
Nov 28, 2013 | Heating & Cooling
I have a 1987 mobile home with a coleman electric furnace model 3400-812. I need a wiring diagram for the repairman to use to rewiring all the new parts. He has installed a new fan blower motor, new...
5cd0d9d4-9d59-458b-ae93-d14f7aa016ab.jpg728c66bc-7660-4666-bc17-bdfa1b3130ed.jpgded744e2-3c31-4bc2-aec3-aa2d40664be6.png
I mean this respectfully, if the technician cannot wire a unit without a wiring diagram , he is not competent to do the work.
It is really very simple, If you look at the power lines entering a building, ther are but 2 hot legs of 115 volts for 230 volts and a earth / ground, every wire we will ever see are these 2 hot legs or a combination of them.
Every circuit requires 2 sides/legs of power, a device and a switch, begin at L1 go through switch to load return to opposite side of power from where you began, very simple.
If you do not know this a wiring diagram will tell him nothing but how to blindly try to follow some diagram he has no grasp of the theory behind or he would see how simple his dilamna is.
Oct 19, 2013 | Coleman Heating & Cooling
Goodman furnace that was working fine until i went out of town for 4 days, turned off the power, and now cannot get the electric ignition to work [although it did fire up for 1-2 seconds the 2nd tim
You need a heating guy, not electric guy. Most heating serviceman are well schooled in power wiring and if by some chance it is wiring, they can help. But it sounds like a furnace problem. I would need your full model# to help trouble shoot the exact problem.
Nov 22, 2011 | Heating & Cooling
I need a wiring diagram and sequencer part Number for e2eb-015hb nordyne electric furnace
any sequencer will work as long as you have the same number of stages. hope this helps.
Aug 09, 2011 | Heating & Cooling
Heating & Cooling Logo
805 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
