Question about Plantronics AUDIO 90 F/E Consumer Headset
Plantronics USB DSP v4 adapter accting wierd....
So I got a plantronics headset 4-5 years ago and it came with a USB DSP v4 adapter, the original headset broke and I have replaced it with a cyber accoustic headset its worked perfectly until today after I installed a Microsoft Xbox 360 controller onto my computer and since then I've been getting distorted, scratchy sounds with plenty of popping.
I have made sure it was not headset issue since I plugged it into my audio jacks and it works perfectly.
I've also noticed that the name of the device after I go to device manager has changed from "Plantronics Headset" to "USB Audio Device"
Any help would be appreciated.
2 Suggested Answers
onyeobike
  • 70 Answers
SOURCE: Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
Posted on May 21, 2009
SOURCE: Plantronics DSP 400 Headset does not work on Windows 7
http://insigniaproducts.com/products/computers/D400.html try this
Posted on Jun 05, 2010
I need to know what splitter I can use for a Plantronics Blackwire C220 headset. I need to be able to plug in 2 headsets and use one to listen only and one to talk and listen. Please tell me what splitter...
There is not a USB splitter for computer headsets like the Plantronics BlackWire C220, you would have to go to a commercial grade headset to have that function. You can use any of the Plantronics "H-series" headsets with the Plantronics Y-training cable (model 27019-03), along with a USB adapter like the Plantronics DA40 or DA45 for training purposes.
Good luck from Headsets Direct!
Sep 14, 2011 | Plantronics Blackwire C220 Headset
Can't hear my pc to head set..can u help
Hearing a Plantronics Voyager 510 headset through a computer:
To use a Plantronics Voyager 510 headset through your computer, you either need a USB Bluetooth adapter or you must have Bluetooth built in to your computer. Once the Voyager 510 headset is "connected" to your pc (by one of the mentioned ways), you may need to go into the control panel on the computer or the specific software program being used to set the Plantronics Voyager 510 headset as the "default device". Keep in mind that the headset has to be powered on and to also have to activate the headset to connect to the Bluetooth adapter or computer.
Good luck from Headsets Direct - 800-914-7996.
Aug 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
I have a Plantronics Voyager Pro and it will not take a charge. I plugged the charger into my phone to check it and it does work on my phone except not with my blurtooth. Thanks for your help.
If you have the Plantronics Voyager Pro headset, you should be using the ac adapter that came with the headset ( model 79414-01 ). If the headset will not charge, it could be broken or the internal battery may be worn out. Keep in mind that the Voyager Pro has a one year warranty, and Plantronics will replace it within the warranty period.
Plantronics Voyager Pro Headset
AC Adapter for Voyager Pro Headset
Feb 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Where can I download a driver for my plantronics dsp 500 headset for Vista?
LJBENGE try to visit this site http://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?type=Hardware&s=Plantronics%20DSP%20500%20headset and try the drivers for vista... good luck!
Jan 19, 2010 | Plantronics DSP-500 Headset
Does the plantronics dsp500 headset have a microphone?
Yes they do have.
Hope i helped you.
Thanks for using 'Fixya'.
Jun 23, 2009 | Plantronics DSP-500 Headset
Thanks.
May 21, 2009 | Plantronics DSP-400 Headset
Plantronics headset
Some additional information may be helpful. Is this a USB device, a standard analog audio device with connectors like a headset for a radio or the electronic ones in airplanes or what (wireless)? I am familiar with a DSP-400 and the model number for these devices is on the bottom of a fairly sizable plastic box near (about 2 feet from) the USB adapter.
Oct 25, 2007 | Radio Communications
ITunes or sound card line in with my USB Plantronics DSP-500 headset
Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in at most minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
Jan 04, 2007 | Plantronics DSP-500 Headset
Plantronics AUDIO 90 F/E Consumer Headset Logo
579 people viewed this question
Top Plantronics Radio Communications Experts
Ed Nelson
Ed Nelson
waldofrog
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
