Question about Maytag Neptune MDG5500AW Gas Dryer
I checked clothes just before cycle was ended and can't restart
The interior was quite warm and when I tried to restart the dryer it just beeps at me. I've unplugged and then I get a readout that says PF but it still beeps when I push start or off
  • 979 Answers
This code is obviously protecting the dryer from doing further damage to itself. This is like a breaker. Call a repairman and have it serviced. If it is more than 12-15 years old, consider a new one.
Posted on Jan 14, 2009
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
LG dryer restarts after cycle
check one of the button are stuck first
Jul 22, 2013 | LG Dryers
We have an estate by whirlpool dryer that quit working. During last cycle it made a loud bang noise that ended the dry cycle and the clothes inside were dry. When we tried to restart it, it wouldn't...
The fuse is tied into the door switch circuit and looks like this:
Unplug the dryer and remove the rear cover. All the heater components is back there.
Service manual and more info are HERE at my FixYa tip.
Jul 17, 2011 | Estate TEDX640JQ Electric Dryer
The dryer simply doesn't dry my clothes
Are the clothes warm after cycle? If not heater coils may be bad. Is lint trap cleaned out? Have you checked the vent that exhausts the air to the outside? make sure it is cleaned and kink free and the air is flowing freely. If you can get to the end of the vent outside you could try running the unit and check to see if you're getting good air flow outside from the vent.
May 27, 2011 | Amana Dryers
Heats up but takes several cycles to get clothes dryer
Check for a restriction in your exhaust vent. not just behind the machine but all the way to the outside vent,should have good warm airflow at outside vent. With no good air flow you have no way to get rid of the moisture. and all you will end up with is warm moist clothes. this can happen slowley happen over time and next thing you know it takes several cycles to dry the clothes .it cost a lot to dry them this way
Aug 08, 2010 | Amana NED5400TQ Electric Dryer
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
101 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
