Question about Philips 50PF7220A Television
Philips 50PF7220A powers up, but I get no pic
Nothing seems to work. I get a slight picture (white) and a large power draw but I can't even get the menu to pull up. green light on front panel and a couple of green lights inside the back. I don't have a remote or a cable card. I also powers itself down after 10 minutes. Thanks for any help.
  • 1 more comment
  • nornotlob Nov 13, 2008
    I just got the unit home. I tried the unplug reboot a couple times. Still has same results
    Thanks guys I guess I hauling it down to the repair shop. Anything you can tell me....
    Thanks for the support. I off to the repair shop.
    Sergeant:
    Champion:
  • 283 Answers
This symptoms mostly on picture tube problem. But if you can open your tv please check if thier is a burned resistor/capasitor inside. If you can see a burned part/s then replace it. But if your unit is still covered with warranty then go to its service center..please dont rate me if you are not satisfied with my suggestion. Thanks for usimg Fixya.......
Posted on Nov 13, 2008
    President:
  • 1,952 Answers
Chip failiar change the board
indicate an over-current condition and high voltage shutdown. The most common cause of this is a bad horixontal output transistor
  • mohammed marika thambi
    mohammed marika thambi Nov 13, 2008
    check ur board whether voltage passed in to it?
    Genius:
  • 1,269 Answers
There's an internal electronic component that is burned. You need to take apart the tv casing and visually check the burned parts. First, check the power supply board then proceed to the convergence circuit. You might as well check the lamps if it's already blown. If you are a bit hesitant to do this stuffs, its either you can claim your warranty where you bought your tv or bring your tv to nearest appliance repair center as your last option.
    Genius:
  • 1,142 Answers
Try unplugging the power for 10 mins and then try should reset the unit.
  • Maanita Chadha
    Maanita Chadha Nov 13, 2008
    Well it seems that the unit is not getting the power required by the picturetube, you need a tecnician to get the power supply unit repaired.
Philips 50pf7220a/37 no power
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Especially to Philips Brand.
Oct 11, 2014 | Televison & Video
Philips magnavox,9p5040c102 tv has power but no pic or sound, what is wrong, worked fine yesterday
I have same problem with mine, the power button turns red (as usual) but no picture. When i turned mine on last night it made a crackle noise and thats how it all started. I can even hear the normal sounds it makes as if it were turning on, but still no picture. Its a great tv I would hate to throw away. I want to fix it myself any help would be appreciated!
Aug 21, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have the same model. My picture is bad my white
If the pic seems dull and the colors are all washed out as well as the tint not being able to be ciorrected to correct tones. Its almost always caused by the CRT coolant needing replacement. You can get the phillips CRT coolant kit from www.tvrepairworld.com the kit contains the coolant for all three CRT's and the CD with instructions.
Jul 18, 2010 | Philips Magnavox 9P6034C 60" Rear...
Blanking red light on this tv
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 31, 2010 | Philips 50PF7220A Television
Blues' appear more green
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 05, 2010 | Philips Televison & Video
TV wont come on
I just fixed my 50pf7220a phillips last nite....i took the back off and found two bulged capacitors on the power supply board...i tried un soldering them in order to repleace them but could not get them hot enough to melt the solder.....so i called this number (812) 867-7583 to get a new power supply......tell them the model number of the tv and they have the power supplies in stock mine was 129.00...the power supply is the large circuit board near the center of the tv.....its easly to replace....lay the tv screen down on the floor remove the large back ....about 70 screws....look for the slighty bulged capacitors...on the power supply board.....label all of the connectors to the power supply board and make a map of where they go .... remove the 8 screws that hold the power supply board in place.....get the new board and rehook....making sure that all connectors are tight.... please use two people to move this tv its top heavy....good luck if you have questions please post here and i will try to answer.....I am not a tv repairman but just a concerned consumer.....i understand that capacitors will go out once they reach 2000 hours.....
Feb 07, 2010 | Philips Televison & Video
IT WONT POWER UP.IT TRIES BUT IT APPEARS NOT TO HAVE ENOUGH POWER TO FIRE UP.
Ur power board it dead.Must replaced the power board to get the power back.
Jan 27, 2010 | Philips 50PF7220A Television
Plasma Philips 50
Ur power board have burn capcitors,like puff up or burst open,must changes these capacitors.Know how to solders?Tries Shopjimmy.com,Ebay.com for buying reburbish power board.
Jan 11, 2010 | Philips 50PF7220A Television
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
Phillips Plasma Error
That unit is a BP2.2UAA chassis and from the sympotoms you're describing you have a power supply problem. The power supply is an smps (switch mode power supply) Philips p/n# 996500033880 and available at Vance Baldwin for $473.58 plus shipping, which includes a $250.00 core which you can get back when you ship them the old part.
If you buy the supply yourself and attempt the repair it's a simple plug-n-play but you should also check the Y & Z sustain boards for possible shorting.
Bill
May 19, 2008 | Philips 50PF7220A Television
Philips 50PF7220A Television Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
