BLUE NOT FOCUS - Televison & Video
  • acadint Nov 14, 2008
    Thank you very much!
    President:
  • 1,952 Answers
What is ur model and brand
Posted on Nov 13, 2008
  • mohammed marika thambi
    mohammed marika thambi Nov 14, 2008
    There are a few malfunctions that can cause such.
    ONE: Mirrors out of location. But it usually throws the picture off
    center, also. This can be caused if the set is dropped or kicked badly.
    TWO: Out of focus. Can be caused by drift of the circuits or from a
    malfunction of the video drivers. You can check this by going to the
    crosshairs and see if the lines are sharp and narrow. If not, then the
    focus is off badly - most likely the blue gun. You may be able to set
    the focus and other levels for brightness and contrast and color to
    optimize this weakness as these are all somewhat interrelated,
    especially in the extreme settings. You can make adjustments for these
    above what is available from the OSD by getting into the service mode.
    See this web site for instructions on how to enter it. http://www.fixyourowntv.com/servicemenu....
    THREE: Worst case is the blue gun or projection tube is failing and
    needs replaced - which I don't recommend due to the very high cost of
    doing so.
    FOUR: And it is possible the blue gun/tube has been knocked out of alignment by dropping or moving the set.
    I favor the focus adjustment as the first remedy to try. You can do
    that yourself. But if it turns out the mirror is out of location or
    the blue gun is defective you will need a technician for help on those
    items.
Just the blue on my rca projection tv is blurred. on the auto convergeance it says it cant read the sensor. on manual the cross hairs for the blue are oversized and blurred. i tryed tuning in the focus but...
Have you try adjusting your focus/screen drive controls to Tube R/G/B you have a focus/screen drive control block to adjust each Tube 3 controls ontop 3under them top ones are for Focus bottom is for screen drive.Red/Green/Blue Tubes.You might need to replace convergence IC, what is your Model number printed on back of TV?
Mar 24, 2010 | Televison & Video
Blue outlines on screen. not a screen burn or convergence problem
I am not familiar with that particular model but most are similar.
It may need the blue focus adjusted. Most tv's have some type of automatic focus. If the blue is out of focus it can "bloom" beyond the red and green. There should be a focus block with 6 adjustments (2 rows of 3) behind the speaker cover. I wouldn't mess with the one labeled screen or block. Adjust very carefully. They are usually in the order Red-Green-Blue with the focus on the bottom row.
Mar 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a Mitsubishi RPTV. Everything looks fine except for the blue colors look blurred. I have tried software convergence but the blue still looks blurred and strange. What can I do?
ADJUST THE ELECTRICAL FOCUS. AND THERE IS A MECHANICAL FOCUS ALSO. SET THE ELECTRICAL FOCUS BY LOOKING DIRECTLY INTO THE TUBE AND ADJUST IT SO THE TUBE SURFACE IMAGE IS SHARPEST. THEN LOOKING AT THE REAR OF THE SCREEN ADJUST THE MECHANICAL FOCUS, ON THE LENS UNTIL IT IS SHARPEST. ALSO IT MIGHT NEED A CLEANING OF LENS&MIRROR. DIRT AFFECTS BLUE LIGHT FIRST.
Dec 27, 2009 | Televison & Video
Hitachi 53UWX10BA dynamic convergence works but blue is blurry
I know this set very well---you are saying convergence adjusts ok everywhere? If you understand that the blue is usually de-focused a little----there are only two ways to adjust the focus of each tube-----
1.) Behind the front speaker grill there is an inspection plate---with it removed you will see a small black plastic block with 6 controls on it; it is the MASTER SCREEN/ FOCUS BLOCK
2.) THREE of the controls left to right are Screen controls(red, green and blue) and the other 3 are FOCUS--IT IS ALL black and you need to look close to identify which is focus and which is screen---you are looking for the BLUE focus control(one of the 6)
3.) With the convergence grid on screen cover the RED and GREEN lens in the set and try to adjust the focus of the blue(I presume you know how to put the set into the Convergence mode?
4.) The only other way to adjust the Blue focus is from the back of the set---with the Red and Green lens covered up place a blanket over the top of the set that covers the whole screen--from the back of the set you will note that all three of the black focal lens have a wing nut---with the convergence grid up and only blue lines present(Green and Red lens covered with a cloth) look from behind the set at the grid---loosen the wing nut on the blue lens and slowly slide the lens left or right until the blue has the best focus possible----if it will not adjust with the focal lens or the front focus control you have a circuit problem.
I do this here for free and if this information helps you take a minute and give me a vote here. If you have any questions or need advice reply to this posting here and I will assist you.
SD TECH
Sep 14, 2009 | Hitachi 53UWX10B 53" Rear Projection...
AKAI PT5598HD - I HAVE REPLACED THE CONVERGENCE BOARD AND PICTURE AND SOUND ARE "ON" BUT "PERFECT FOCUS" WILL NOT BRING BLUE INTO FOCUS. "PF" STOPS AT 37% - RED AND GREEN PATTERS ARE SHARP BUT BLUE IS...
Most of these sets have a SCREEN/FOCUS block---usually all black with 6 controls----you need to look close at it as one row of 3 will be screen controls---don't touch those----the other 3 will be FOCUS- MARKED in little letters will be r,g,b(red,green blue). TWO ways to adjust the focus: 1. carefully locate the blue focus control and adjust to see if blue will improve in focus. 2. each of the 3 large lens where the picture comes out have a wing nut and a slot--you can loosen the nut and turn the lens---usually best focus that way is if the part that turns is in the middle of the available area to move it.
I should point out that all projection sets intentionally de focus the blue--the lines if blue should be clear but never as perfect as green or red--this is normal.
I do this here for free so if this has been helpful give me a vote here.
if you need direct help:
etower.766@netzero.net
Aug 20, 2009 | Akai PT5598HD 55" Rear Projection...
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
The BLUE crosshair will not focus,
go here
this is for sony but your should be close enough. you want to manually focus the blue gun.
please mark post fixya!
Feb 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Blue blurry on perfect focus
Did you try the manual lense focus in the back? There is a wing nut on it and it's pretty easy to change. You just need someone to look at the TV and tell you when it looks good. Additionally for the Blue tube, it's on the far left. You take off the bottom panel in the back to get to this area. Good Luck.
Jan 13, 2008 | Samsung PCN5425R 54" Rear Projection...
Blue problem
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Samsung HCM5525W 55" Rear Projection...
Color Alignment
get a shop manual,it tells how to do the whole convergence process and how to store it to the rom memory to save it.
Mar 15, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
