Question about Frigidaire FRT21H8 Top Freezer Refrigerator
REFRIGERATOR NOT COLD
MY FREEZER IS WORKING FINE, BUT MY REFRIGERATOR IS NOT COLD. I HEAR IT RUNNING IN THE FREEZER, BUT NOT THE REFRIGERATOR.
  • gns1998 Nov 18, 2008
    I appreciate the help. However, where is the evaporator coils, and how do get to them? What tools do I need to get to it? This is for the Frigidaire FRT21H8 Top Freezer.
    Sergeant:
    Champion:
  • 214 Answers
I have experienced this also.
If the drain under the evaporator coils in the freezer freezes up it will cause this. Because the coils ice up. Manual defrosting with hair dryer will get working again, but if drain is stopped up it repeat.
Maybe piece of paper or food in it.
OR the defroster heater element is burnt out. Same results.
Most all top Freezer Models.
Posted on Nov 13, 2008
    Sergeant:
    Champion:
  • 214 Answers
All the food will be removed first.
Shelf will have come out.
There should be a few screws in the back wall of the freezer, fan may have to come off first.
Posted on Nov 18, 2008
I have a Kenmore top freezer refrig, My freezer works fine. My fridgerator is not cooling. I can hear the fan running. What could be the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | Kenmore Top Freezer Refrigerator
Fridge not working can hear fan come to a halt when you open door. Freezer water and ice machine all working fine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 15, 2011 | Samsung RS2578BB Side by Side Refrigerator
Side by side refrigerator stopped getting cold (freezer stopped also). When plugged in, all lights and sounds still run fine.
If all fans are running and no cold at all check to see if compressor is running(under rear panel). If you hear it try and start then a click then the start relay pack may be bad,
Oct 28, 2010 | GE GDS18LBR Bottom Freezer Refrigerator
Freezer is working fine. The refrigerator is not
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
The Refrigerator does not get cool but freezer works fine
Make sure that you are not overloading the top shelf of the refrigerator section. There is a small vent near the top where cold air blows in. You should also be able to hear a fan blowing as well when the compressor is running. The fan will be easier to hear when the freezer door is open. If you can't hear the fan, likely the motor has gone out and the cold air is not circulating like it needs to be.
Oct 02, 2009 | Frigidaire Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
MY refrigerator is running but is not getting cold.
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Oct 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerator is at80 degress
This unit uses the cold air from the freezer to cool the fridge, you will find that the air duct has frozen up, completly defrost overnight with the doors open, this should rectify fault. Regards Advisor
Mar 06, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
562 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
