Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer quits working. Let it set for a few hours then it works
The tub is full of water and turning the selector switch sevral times does not help. It is like I lost power. Letting it set for a few (3) hours it will start working. I was wondering if the pump is plugged and the water can't drain very fast would this cause the pump to over heat and we have to wait for the reset to kick back in? How can one easily unplug the pump if indeed a sock or something else has gotten into the pump?
    Genius:
  • 1,028 Answers
You may have overheating motor ..once the motor gets hot it will shut off after cooling down it may restart..overheat may be due to bad motor ,wiring or timer ..sometimes the timer will cause the motor to try to run in both speeds at the same time thus overheating if motor sounds heavy during run suspect this may be reason
Posted on Nov 13, 2008
Electrolux ESI 6180
I was shown how to clear your dishwasher and keep it running much longer. however, be careful when doing this. start with an empty dishwasher. pour 12 cups of cold water to the bottom area of tub and wearing latex, or rubber gloves, measre and por in exackly 2 cups of ammonia. let that solution sit there either all day, or overnight, at least a few hours, then run it through your machine, do not add anything else. do not do this with small children around. if you prefer buy the largest jug od vinegar (white) and pour it full strength into tub of your macine. let stand sevral hours, then put through a light or regulsr cycle. if you encountet that same problem empty, press drain cycle. retry usingrinse cycle instead. let me know if his resolnves your problem.
Nov 15, 2013 | Electrolux Dishwashers
Washer quit working in rinse cycle before spin cycle tub full water does nothing but fill with more water when you increase water level
99% of the time the lid switch is what causes this issue, below are two links one where you can get the lid switch and the other explains how to take the washer apart to test and access the washers lid switch.
Cheap Appliance Parts Click Here
Good luck with your repair!
How To Take Kenmore Washer Apart Click Here
Mar 05, 2011 | Kenmore 26882 Top Load Washer
Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Apr 10, 2010 | Whirlpool Washing Machines
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Wash cycle won't start after the tub fills up with water.
There's no delicate or regular spin or agitation If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Kenmore 90 series heavy duty washer
If it fills up to normal level on other settings then the water selector switch is bad.
Look at the back side of this switch and you should see a tube connected from the switch to the lower part of the tub. Take the tube loose at the switch and blow through to check for any blockage. Look at the tube for holes.
Nov 14, 2008 | Kenmore 22422 Top Load Washer
GE washer model WNSR3120
Selector switch
Clutch assembly
Drive motor
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 21, 2008 | GE Washing Machines
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal De
