Question about Roland MA 8 Computer Speakers
Cell phone static on Roland MA-8 speakers
I am greatly annoyed by the very loud static type noise from my speakers whenever someone in the area turns on a cell phone.
I am using them as speakers for my computer. The sound is awesome but so is the static. I know the static is from a cell phone because it happens when I turn my cell phone on.
It is a di-di-di type noise.
Is there a way to ground the speakers? or maybe put a filter somewhere or maybe sheild the cables? Any suggestions? Thanks in advance.
RobertJ.
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I want to mount B-Tech
As for ? 1. The brackets will be strong enough to hold the speakers up. ? 2. If you attach the brackets towards the top of the speaker you will not hit the amp inside. Sense you are using just half inch screws you are safe. I would use the #6 screws.
Good Luck and please accept the answer
Posted on Oct 04, 2010
Loud speaker static from 2002 Mitsubishi Eclipse when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to g
The fuse might be built into the cable to the lighterand/or radio. It's called "fusable link", this type of fuse looks like a cable. Or another type of fusable link might be in the fuse box under the hood near the firewall.
Feb 01, 2015 | 2002 Mitsubishi Eclipse
Whenever the speakers are turned on there is a loud continuous tone that starts low and gets higher. How do I make it stop?
Hi. Regarding your issue, there might be a problem with the cable or the jack coming from the speaker itself. Better to have the speaker checked to its manufacturer, or have it replaced for you not to hear any annoying noise no more.
Jun 13, 2011 | Harman Kardon HK695 Computer Speakers
I have also a problem with my samsung s3500.Whenever i try to use camera it says 'check camera connection' and whenever someone calling me i can't hear her voice. i need to select the speaker on so i can...
You have 2 problems there. First, the error from the camera states that there is a problem with the camera's physical connection. It is telling you that the cable/wire that activates the camera is either loose or damaged.
With the loud speaker working and the earphone not means that the speaker is also either loose or damaged. Both the speaker and camera are on the same area in the phone and thus have a connection problem.
You have to have it checked with Samsung's Service Center.
Jan 28, 2011 | Samsung Cell Phones
Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Mar 24, 2009 | Gateway Media Center 610XL PC Desktop
Static noise coming from interior rear by speakers
CHECK REAR AMPLIFIER (INSIDE TRUNK) BAD CAPACITOR OR BAD CONNECTION. REPAIRED MINE TODAY.
COST $30.00-
Jan 08, 2009 | 2003 Jaguar S-Type
Amplifier for my velodyne cht-8 is making noises
Yes the amp section can be peplaced.
Call Velodyne, the amps are not that expensive.
Jan 01, 2009 | Velodyne CHT-8 Subwoofer
High pitched ringing when LCD is on
Obviously it's crosstalk from the supply for the LCD backlight supply into the audio amp...it's odd, because the supply should feed LEDs rather than a CF...but I'm thinking maybe a label in the phone got wet and is conducting your whine over to the audio bits.
The general solution is to crack the case, find the audio circuits, and make sure there is no deposit linking the areas such as from water condensation, spilled coffee, soaked label, etc. You can hear when you've fixed it!
Aug 15, 2008 | T-Mobile Wing™ Smartphone
Static on screen and then turns itself off then on
My first aproach will be to see if the tv reacts to tap on the sides if you see a reaccion when you do it most likely you have a loose conection and need to call someone to find it and resoldered it.Dont do it yourself if you dont know how.
Sep 11, 2006 | Proscan PS27125 27" TV
How do i get rid of this annoying static?
Static is caused by one a weak signal and two a defective circuit board in the phone.
Apr 08, 2017 | Sony Ericsson Z520a Headset Headset
Static noise so cannot hear anything
Do you have WI Fi nearby as it distorts signal sometimes. Changes wi fi band width and it should clear problem.
May 31, 2006 | Sony Ericsson T610
Roland MA 8 Computer Speakers Logo
94 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
