Question about HP Compaq Presario V2000 Notebook
Using the laptop w/o an docking station
Can you shut the laptop and use and external Monitor, Mouse, and KeyBoard?
  • 29 Answers
Go to control panel>power options>choose what closing the lid does.... in this screen Choose the option that says DO nothing. This will allow you to close the lid and still work of the externals.
Posted on Nov 13, 2008
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Dell Latitude E6410 : Mouse & ext. Keyboard lost when putting back into docking station
Go to the Control Panel in your start menu whilst the PC is in the dock,disconnect the things you want it to detect, then click on "Add a device" and connect them one by one :)
Aug 16, 2012 | Dell Latitude E6410 Notebook PC - Intel...
I want to use a external monitor keyboard mouse and close the lid and keep working on the computer
I'm not sure if you'll be able to close the lid because you might need a laptop that is designed to work with a docking station to do that.
Anyway, you can hook an external monitor, usb keyboard, and usb mouse to the laptop and continue working as usual.
May 07, 2012 | Computers & Internet
Docking station USB ports are not working - Laptop is Lenovo x201
I unplugged the moniter, mouse keyboard and power. I plugged in the mouse, keyboard, moniter and then the power. I placed the laptop on the docking station and it worked.
May 02, 2011 | IBM (250410U) Docking Station for ThinkPad
Keyboard not working on one side of switch
the GCS632U has keyboard and mouse emulation that may not function correctly with docking stations. To ensure the KVM it self is working correctly I would suggest plugging the single USB from the KVM directly into the laptop and see if you have the same keyboard problem. This will at least tell you if the KVM is working properly or not.
May 16, 2010 | IOGear GCS632U 2-port KVM Switch
LAP TOP WILL NOT WORK WHEN PLUGGGED INTO DOCK. tHE POINTER FREEZES WITH THE REMOTE AND ALL FUNCTIONS TO LAPTOP USULLY FREEZE. MY 1.44 MEG FLOOOPY AND MY POINTER WILL WORKSOMETIMES WORK UT iF i UNPLUGGED...
unplug everything from the docking station, and press and hold the power button for about 15 seconds. Afterwards, plug in only the power and the monitor to the docking station and dock the laptop (make sure the laptop is turned off before docking and turn on after docking). If you still have issues it could still be hardware or software at this point. If you do not have issues, plug in one thing at a time to the docking station (mouse, keyboard, ect.) and restart the laptop each time until the problem starts again. this is how you will know if a device in the DS is causing the issue. if your monitor is vga (port on back of docking station where monitor is plugged into is blue) try plugging it directly into the laptop. also try plugging in the keyboard and mouse directly into the laptop (if they are usb) and anything else you may have plugged into the DS. This will be a better way of testing your devices. If all devices work fine, i would say that it could be more of a hardware issue with your DS.
Jul 22, 2009 | Dell Latitude C600 Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
Docking Station problem
You can try to update any system utilities drivers and docking station drivers. However, I found that with IBM and Gateway, when you remove a running machine from the docking station they tend to glitch just a bit and when you redock them they have issues. Your issue is the docking station attachments, I've also seen issues with the monitor only, mouse only and keyboard on the laptop, all not working. I've had a couple that if I used the "safely remove hardware" then they would work when removed then redocked, but not all machines give the safely remove hardware option with the docking station. If yours does, try that. If it doesn't and there are no driver updates or the updates don't work, then, unfortunately, I'm afraid you'll just have to live with restarting after every redock. One other thing you might try is, after redocking, do a hardware search. It may find the attachments. I know this is also a pain, but it may be easier than rebooting every time.
Jul 09, 2008 | IBM ThinkPad X61 PC Notebook
Docking station trouble
You will need to dock the closed laptop first, then use the power button on the dock to turn it on. This will result in the output to the monitor. Alternatively, if you have the laptop open, you can toggle between the laptop LCD and external monitor (or both) by holding the blue Fn key (on the laptop keyboard) and pressing F5. Best regards, torgo
Jun 03, 2007 | Dell Latitude D600 Notebook
HP Compaq Presario V2000 Notebook Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
