I can not get the internet to work on my laptop after I have signed into my network
Check if your getting the correct IP address make sure your gateway is your router IP address
Posted on Nov 13, 2008
I do not know how to enable the wireless internet on my Dell Insperon B130.
1st try / keep hold of FN and press the appropiate F key (for example FN and F8 together)
2nd try / There may be a little switch at the front of your laptop, just below the mouse pad and keys.
3rd. try /Click start, control panel, network and internet, and then connect to a network.
Click on the wireless network you are trying to connect to and type any password in (if any password is required)
Hope thsi helps and please rate, Thanks
Mar 16, 2011 | Dell Inspiron B130 Notebook
I have an acer aspire one laptop that will not connect to internet thru wireless connection. System shows that wireless connection strength is excellent but internet explorer cannot display webpage. ...
1.- Try to find the wireless card switch (or button). Look the wireless led indicator, must be on.
You should surf if the led is on.
2.- If not works, go to device manager and look to your wireless device and turn the switch on and
off again. Look if the device is accepted without any sign. If the device get any sign then you
have problem with your wireless driver. If no sign. Open My Computer and then open networks
or my network places, and try to access to any other computer you have.
3.- If the device is ok in device manager and the led indicator is on and you can access other
computer thru network places, then open Internet explorer, go to tools, then go to internet
options, then go to connections and there click on Lan settings. In the proxy section uncheck
the box. Restart your Internet Explorer and it must surf now.
Good Luck and remember to rate my answer.
Feb 16, 2011 | Acer Aspire One PC Notebook
When i sign in yahoo messanger after 4 or 5 minuts coming message stop working yahoo messanger like that. now i need how can i solve this problem
Usually messenger encounters a lot of problems as a result of poor internet connection. When messages stop going through your messenger it usually is a sign of a fluctuation in the internet network.
But to ensure that the problem is from the network uninstall your yahoo messenger restart your unit and install a fresh messenger. If the problem persists then the fault is from your internet connection.
Hope this solution has been helpful?
Nov 27, 2010 | Computers & Internet
Is ps3 network down as it will nt let me signin 2 network 2 play games online gettin mad
its not sony fault ,i just found out today it ur service if u have a DLS ur going to keep being signed out till it finaly sign u out for good, just call ur service and change ur internet service or upgrade it ,ok dont wrry lol
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
My wireless laptop worked fine until i returned from vacation. Now i can't sign onto the internet. It says isp or no newtwork. What happened when I used this on vacation under my cousins router?
Check under network connections and see which network is set to default You may be trying to sign on and connect to the wrong network.
Please rate my help++++ Thanks for using FIXYA
Nov 24, 2009 | Microsoft MN-700 Wireless Router
Can't connect to internet
CHECK THE DEVICE MANAGER: CHECK THE NETWORK ADAPTER/S IF THEY ARE PROPERLY INSTALLED [NO X'S NO YELLOW SIGNS ON THE ICON]
Sep 20, 2009 | HP G60-120US Laptop
How to connect wifi with acer laptop
Any wireless router will work. You just have to find the router’s signal on your computer (and sign in to the network potentially).
Your laptop should have a built in wireless card. If it doesn’t, you won’t be able to wirelessly use the internet until you do. I’m assuming you are using Windows.
Click Start at the bottom of the screen, the open your Control Panel. Select the category Network and Internet Connections.
There should be a wireless network setup wizard in there, and will help guide you through the process of setting everything up.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 19, 2009 | Microsoft Windows XP Home Edition with...
Yahoo messenger not signing in
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reg in out to fix the issue
May 20, 2008 | Computers & Internet
Wont sign on to internet
Is the computer recognizing the connection to the network?  Does the home network use DHCP?  How do you have the network setup?  Does this connection work with a different computer?  Try pinging any other computer on the network, and try pinging a website.
Oct 16, 2007 | Compaq iPAQ Home Internet Appliance IA-2...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
