Question about Orion Televison & Video
Switching to digital
I am hooked to cable television but when they tested my set today, via local news station, it said mine is not HD ready. Do I have to purchase a new set with a digital tuner?
  • 4,234 Answers
No. The change only effects people that use rabbit ears or a rooftop antenna. If you receive cable now, no change is necessary. You will not be able to receive the HD channels, but you can't receive thiose now either. An HD set will show you the HD signals that your current Standard Def set can not show. Please note that your current set has a digital tuner but processes analog signals. The "digital" tuner that is requried for rooftop reception is to process digital broadcasts as the analog signals will no longer be broadcast.
I hope this helps,
Dan
Posted on Nov 13, 2008
What do I do to get my signal back on my westinghouse TV that is hooked up to dish cable
If no signal via the cable fitting try hooking set via one of the sets of jacks on the back (audio/video or component) to see if coax input or tuner is bad.
If the set works with a DVD etc hooked to one of those inputs and your cable is good--maybe a bad tuner in the set---also if using a box try hooking cable direct to set to rule out the box.
Mar 17, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
HOW DO WE TUNE THE TV FOR DIGITAL CHANNELS
If your using basic cable then just use auto program and the set does the rest. You will only get the hd stations your cable provider provides using basic. If you use their hd cable box and pay for more hd stations then you will have more.
Dec 03, 2010 | JVC LT-32X575 32 in. HD-Ready LCD...
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
Aug 08, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
When hooked directly to cable, I get a blue screen and sound. When hooked to Componet Video, S- Video, or Composit Video via a cable box, I get a picture and sound. Apex remote will not change sound or...
your cable box rf pass through may be turned off if you can access the menu of the cable box by turning it off and hittiing th emenu button on the cable box with tv on an scroll down to rf out if you need hael call your local cable company
Nov 19, 2009 | Apex Digital AVL2776 27 in. HD-Ready LCD...
How to get hd picture through my insignia tv without digital cable
Unfortunately, at this time, you don't unless it is a powerful station local to you. In order to see which stations are available to you, you would enter the Setup menu of your tv, and then the section that allows you to scan for channels.
Also, digital cable alone doesn't guarantee you'll get HD signal. You would have to order an HD package from your cable or satellite provider. For example, Comcast touts their digital package as if it were vastly superior to the "standard" signal. Whether or not it is would be a matter of opinion, but the digital package is not HDTV. This misconception has disappointed many a subscriber, myself included (until I ordered the HD package). :^ )
Jul 03, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
No HD picture on HD TV
Yes, you need to buy HD station.
But with DVD you can get HD quality without any other station.
Feb 03, 2009 | Samsung HP-S5033 50 in. HD-Ready Plasma...
When I press tv the description says I select the atsc or ntsc
NTSC is the earlier and soon-to-be extinct US standard, ATSC is the coming one for HD and is digital instead of analog in its signal coding. Most later sets will determine what is available and switch accordingly. Many stations are running tests at random now for a few minutes to let you know if your set is HDTV 'ready.' Check with your local station schedules to see if they are listing times for this test signal.
Dec 18, 2008 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
