Question about Ricoh Aficio 1035 Copier
What does troubleshooting code 326 of ricoh copier 1045 means?
What is the problem if the the code 326 appeared?how to solve it?
  • Ricoh Master
  • 2,794 Answers
2nd laser synchronization error. F gate 1 error. This is an optics issue. Try unplugging the machine and plugging it back it to see if the error goes away.
Posted on Nov 15, 2008
Photocopies are not clear even after increasing image intensity.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
Jul 13, 2013 | Ricoh Aficio 1045 Black and White Copier
Code 326 329
still sc329 error
Nov 26, 2010 | Ricoh Aficio 2035 Copier
ERROR TYPE C:
The main machine can be used
normally except for group
affected by the malfunction.
ERROR:
Error 326 C in the 2nd laser synchronization
The synchronization signal of the 2nd laser
is detected by the card detection
synchronization of the main scanning
even if the laser diodes are activated.
Possible Cause:
Faulty connection between the card
Laser detection and synchronization
the diode laser group.
Survey form synchronization
Laser out of position
Defective Laser
Group defective laser diode...
Jul 26, 2010 | Ricoh Aficio 1035 Copier
Sir my Ricoh 1045 machine have SC 326 problem, after taking a single copy the error code comes. please give a good solution to clear my problem. thanks
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
Jun 02, 2010 | Ricoh Aficio 1035 Copier
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
May 26, 2009 | Ricoh Aficio 1035 Copier
Sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Oct 25, 2008 | Ricoh Aficio 1035 Copier
Error SC326 on aficio 1045
Hi there below is what is states in the service manual.
326 C 2nd laser synchronization error
The 2nd laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
• Poor connection between the laser
synchronization detector board and
the LD unit.
• Laser synchronization detector board
out of position
defective
• LD unit defective
Hope this helps you.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
The copier is a Ricoh Afcio 350
SC 326: Laser synchronization detector board cannot receive the laser beam.
Replace the laser sync detector, Part No. A2935310.
Or try the following solution;
Open the front cover and remove the brown inner cover - 2 screws.
The black unit after the inner cover is the laser unit. There are 2 screws securing the laser unit - loosen them.
Tighten the right securing screw while jacking up the right side of the laser unit with a screwdriver.
Tighten the left securing screw and put the inner cover back on.
If SC 326 is still indicated after the above procedure, replace the laser sync detector or the whole laser unit.
Good luck and please rate me, thanks.
Apr 05, 2008 | Ricoh Aficio 450 Copier
We receive functional problem 326.....we cannot solve...pls help
call Ricoh and ask how to get machine in self-diagostic mode (there a keypad combinations to enter this-usually 2-3 keys pressed at once)
May 27, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio 1035 Copier Logo
382 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
