Question about GE 27958GE1 Cordless Phone
Answering machine no longer works
My answering machine function stopped working, and so did my speaker phone. This happened when the corded phone base (which is the main unit) had been accidentally unplugged from the A/C power source. I have since plugged it in again, as well as unplugged it from the jack, and plugged it back in....but the answering machine feature and speaker phone still won't work. It operates as a regular phone: can use the base or handset, and caller ID still works. After I plugged it in again, all I see on the console is a message that says INITIALIZING.... it never stops..... Have called the helpdesk at 1-800-448-0329 and they told me to double check that I don't have voicemail enabled by my local phone company. Well I checked and I don't have it. Any ideas on what to do?
  • 2 more comments
  • Albert Paladino Nov 28, 2006
    There is one more glitch to this problem. Normally when I plug in the phone again, (both A/C and phone line) it has "INITIALIZATION" (not "INITIALIZING", like I originally reported) on the console and the speaker phone feature does not work, nor does the answering machine and no setup appears to work. However, on rare occasions, several days after being in "INITIALIZATION" it comes out of it and speaker phone works but is very garbled (can't hear anything clear). I then try to do setup for answsering machine and it does not work, can't hear anything. So answering machine still does not work.
    I recently spoke to the helpdesk again and they recommended I unplug the cordless handset as well, remove the batteries, as well as unplug the base, and then plug everything back again in reverse order. I end up with the same problem of being stuck in "INITIALIZATION" mode again. I am about to give up and just go out and buy a whole new unit, but wondering if anyone is out there and has any ideas before I do that.
  • angiep Dec 28, 2007
    panasonic kxtg2356 answering machine will not take messages. it says i have tech problems to try again later.
  • Frances Hager Jul 13, 2008
    After a power outage of 18+ hours...we have an identical problem. But I want to add that our caller id was also affected...one time it might ring umpteen times and still won't identify caller...but maybe the next time someone calls it will. Several times i also tried unplugging everything and plugging back in...including the handset...reinacting the initial hook up when we first purchased it...but to no avail.
  • Frances Hager Jul 29, 2008
    Albert, We're still having the same problem with our answering machine not working and we're still stuck in the "intialization" mode. After days of checking and rechecking this site among others for a solution...of which none have been "remotely" feasible to solving our problem...we "hung it up" and just bought us another similiar phone system. Pardon the puns! :)
Pull the power from the back of the phone. Press the format button and hold it. Then reinsert the power plug aand let go of the format button.
Posted on Feb 09, 2008
Wow..SAME thing...this phone system has gotten to be about 10 years old and the gurus or factory service won't help you out too much because of the bell and whistles it has...and time is money eventually...keypad membranes go bad..bugs get in them...the crawlly ones...if they share the place..my "initialization" left me throwing away the headache and going to Walmart...FIX YA!!!!!
Posted on Aug 31, 2008
What is meant when screen says out of range
You will need to take your handset closer to the base because the signal is weak and out of range. Try locating the charging base in a more central location. If this doesn't work try this.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
For more info go to this site
Customer Support
Feb 27, 2015 | Uniden Dect6.0 Digital Answering Syst W...
My phones model ge28021EE3-A have no dial tone but line is perfect with other phone
Try resetting the base(main) unit with the answering machine on it.Unplug it for about 30 seconds then plug it back in.You should be able to use it then.If that doesn't work,try a different phone cord to the base.It should reset though.All this technology,and stupid junk like this happens all the time.Happens to our phone too.Nintendo Wii's too.Good luck! Greg
Aug 19, 2010 | GE 25952 Cordless Phone
Will the answering stop working when the battery is dead in the handset
No,This wont happen.The answering in connected only to the base unit.Answering system and the battery of handset is no way related.
Even the battery is dead the anwering machine will work.
Thank you
Aug 07, 2010 | GE Cordless Phone & Answering Machine...
My uniden hanset stopped working. When I click on
Disconnect your phone from the wall and charger....Take out the Batteries and wait 2 secs...Replace batteries and recconnect phone ..see if this problem is still happening.
1. Disconnect Battery from handset(s)
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Heres a site for more help:http://mycusthelp.net/UNIDEN/supportkbitem.asp?sSessionID=&Inc=1093&sFilA=Product&sFilB=Model&sFilC=&FA=-1&FB=-1&FC=-1
(Copy paste to browser)
Mar 08, 2010 | Uniden Cordless Phone
Uniden base display does not work after chargin for 1st time.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
May 05, 2009 | Uniden DECT 6.0 Cordless Phone ID
Hit the deregistration button. phone will not work now.
Question:
Answer:
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
My phone is dead
Question:
Answer:
Wharfedale DECT TAM telephone/answer machine is flashing CL on the main answer machine base unit. This message is not indicated in the user manual can you please advise? Many Thanks Steven Clifford
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Aug 28, 2008 | Emerson EM-CKT9087 Corded Phone
Can't hear caller
This problem often results from a defective handset cord--check the handset cord by switching it with a good one. If that solves the problem, replace the cord. With a portable phone, substitute a transmitter from another telephone--replace if necessary.
Jan 18, 2006 | AT&T 146 Corded Design Line Telephone
GE 27958GE1 Cordless Phone Logo
407 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
