Question about Dewalt DW735R Reconditioned Heavy Duty 13" Three Knife, Two Speed Thickness Planer
Planer is not feeding wood through without manual force
The planer is not feeding wood through without manual force asnd it leaves black skid marks on the wood from the rollers, its as if the blades and rollers are not on the same plane, the planer isn't that old and shouldn't have these problems.  i had an old dewalt planer and it had the same problem , can you help? please!!!!!!!!!!!!
  • Anonymous Feb 06, 2009
    I just got a new 20" 209HH and I was getting marks on the top and snipes. I lowered the rollers and the snipes went away but the black marks were still there and the wood jumped going in after manual force to start feeding. I noticed the drive roller had the same imprint as the black marks so I increased the depth of cut which was very shallow up till now. It took off the black marks! I still haven't solved the manual force thing.
  • Anonymous Apr 09, 2009
    i have the same thing with mine i have 2 planers and the 735 is the worst planer i have ever got you have to push the wood
    Problem Solver:
  • 7 Answers
I had the same problem...sometimes you have to take the smallest amount off (1/64th) and it might work, otherwise your blades are probably dull. Try to feed the boards through the planer towards the sides, not just the center so they wear evenly across the length of the blades. They wear out very quickly, which makes this planer very frustrating. If you take the top cover off and inspect them, you'll probably see nicks in them and it's time to replace or rotate them. Each blade has two sides you can remove all the screws using the T-handle wrench from the top cover and flip them. Also, as the blades begin to wear, the planer will become louder and louder. That's another way to tell. When you install new blades notice how much quieter it is when you plane boards.
Posted on Aug 29, 2009
Clean the rollers with alcohol and that will work for awhile. Also wax the bed so it can slide better.
Posted on Oct 04, 2009
Put past wax on the deck and rollers. it should slide like butter.
Posted on Jul 10, 2009
    Sergeant:
  • 359 Answers
Maybe trying to take off too much with one pass try one sixty fourth and see if it does better , if so repeat process i have dewalt i take small amounts does fine get to heavy leaves black marks try it
Posted on Dec 05, 2008
I just bought a bran new planer and it isn't feeding or cutting. My wood fits through but the blades are higher than the rollers
There should be an depth adjustment knob to lower or raise the blades. What brand and model number do you have?
see this:
https://www.youtube.com/watch?v=QJZAOIllH3w
Oct 01, 2017 | Tools & Hardware - Others
Dewalt 735 planer trips overload a lot. New blades, thin cut no difference. Run it, without wood, it trips. Overload switch? Checked everthing. Turns free with chains off. Bluespook
id check the feed roller drive or feed rollers them selfs I find due to pressure there under most times they get flat spots in them from sitting makes for a hard start to planer
its best to back off tension rollers when storing these and keep them bearings lubed up well
and yes it happens to sealed bearings too
Apr 28, 2015 | Garden
Wood planer
Unplug the machine and readjust the blade setting to sit just past the blade support
Apr 13, 2013 | Tools & Hardware - Others
Planer will not get up to speed
I suspect that the works are clogged up with wood chips or some long fibers like hair or string. You will have to do enough disassembly so that you can pull out the chips that are wrapped around the shafts, without removing the blades or any of the shafts themselves. The motor, the cutter, and the feed rollers could all be clogged up - as well as the speed reducing mechanism that makes the feed rollers turn slowly. Using compressed air will not do the trick. Needle-nosed pliers and a nut-pick will probably do it. Hair can be hard to see - so be thorough in cleaning. Good luck.
Dec 20, 2012 | Craftsman 12 amp 12-1/2" Bench Planer...
Ryobi AP1301 planer. Suddenly started getting ripples in wood.parallel to blades. Tried reversing blades to unused side, made no difference.Only trying to take of about 1/16". Stock is...
CHECK THE ROLLERS THAT PULL THE WOOD THRU, I HAD TO REPLACE MINE FOR THE SAME REASON.
IF THEY HAVE A LOT OF USE YOU WILL SEE WORN FLAT SPOTS ON THE ROLLERS CAUSING THIS PROBLEM
Jan 16, 2011 | Ryobi Thickness Planer Blades
My 13" DEwalt Planer feed is slipping and leaving
Hello Ken,
The black marks you are seeing are most likely from the rollers that feed the material threw the planner. The marks are left on the board when the board stops but the feed rollers are still spinning.This occurs when the feed table is stickey with items such as pitch. I would clean off the table completly and wax it ( or some type of lube).
Another cause could be the matrial that you are using, if the stock is real rough it will not slide as easy as a smooth board.
I hope this helps.
Shop Dog.
P.S. after waxing or lubing the table run a scrap piece first to wipe off any excess.
Nov 28, 2010 | Dewalt Tools & Hardware - Others
I am feeding the wood but the rollers seem to be lower than the blade consequently the front roller is getting in the way and not allowing the wood to be in contact with the spinning blades.
go to the back of the planer and remove the cover. loosen the bolts holding the blade and let it out a fraction. it should have springs to push it out a little. make sure both blades are out the same abount. it is not hard to do and will be quick.
Aug 31, 2010 | Tools & Hardware - Others
Thickness Planer (DW733) leaves fine scratches on wood surface.
It sounds like your blade holder assy has become misaligned on the blade drive shaft. Try if you can to use a straight edge on 2 planes 90 deg apart and see if there are any gaps in either of the srtaight edges. I suspect that the blade drive holder has become slightly dislodged from the drive collar on one end allowing the blade drive to tilt on the drive shaft. I had the same thing happen on another brand named Planer and it was a matter of reseating the collar to cure the stripes. Sure took a long time to sort out. Good Luck.
Feb 06, 2010 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Delta rockwell 22-200 planer. I need a manual.
Check on www.owwm.com. You will probably find your machine on their and resources to help you in your quest. It's a great site for old tool hounds.
Jan 08, 2010 | Delta Masonry Tools
Dewalt DW735R Reconditioned Heavy Duty 13" Three Knife, Two Speed Thickness Planer Logo
3,001 people viewed this question
Top Dewalt Cutter Tools Experts
Are you a Dewalt Cutter Tool Expert? Answer questions, earn points and help others
