Question about Linksys Wireless-G WRT54G Router
Connected but not working...
I live in a 4-person apartment and we use a Linksys Wireless-G 2.4 GHz router. It's password protected and we run into the same problem a couple of times a year where our wireless just stops working. Right now I can "connect" to the network from my Mac, but I can't get online. Since none of us are very router savvy we end up calling the outsourced Linksys hotline and (I guess) reconfiguring our router...when really I feel like there's probably a much easier solution (i.e. pushing restart). I've been trying to mess around with the settings after opening 192.168.1.1 in my browser, but I don't know what half of the acronyms mean and just need a little help to fix the internet before my roommates go crazy!
    Genius:
  • 1,124 Answers
WRT54G
Before you begin, please try to configure the WRT54G from a hardwired PC for simplicity. Whenever security is changed you’ll need to change the settings on all wireless units so it’s a good rule of thumb to do security changes from a hardwired PC if possible.
Accessing the Router
1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP)
2. When "Internet Explorer" opens type the routers IP address into the "Address" bar and hit the [Enter] key (The Wireless routers default IP address is http://192.168.1.1)
3. The "Enter Network Password" window will appear.
4. Skip user name and type in your password (admin is the default password), and click OK
Setup Page Security Options
When you arrive at the Setup page, you'll see the bulk of your wireless security features. There are three things you're going to want to set on this page:
1. SSID
a) Delete linksys from the "SSID" field
b) Input your own unique SSID. We general recommend something easy to remember, but secure enough to where people would not be able to guess it easily. Sometimes your best bet is to use your last name and add some numbers, in this example we’re using linksys12345678910.
c) Click Apply then Continue
2. SSID Broadcast
SSID broadcasts allows other 802.11b and 802.11g users to see your Access Points SSID, by disabling this option is similar to closing your binds and not letting people see through. If you have Windows XP computer(s), do this step last.
a) Select Disable on the “SSID Broadcast”.
b) Click Apply then Continue
3. WEP
a) Set “Wireless Security” to Enable.
b) Click the Edit Security Settings button.
c) A window will appear prompting you “Do you want to enable the Security Encryption?” click OK.
d) When the "Security Settings" Window appears, set the “Security Mode” to WEP*. Then set the “WEP Encryption” to the 128 bits 26 hex digits option.
NOTE: 128 bit WEP may not work on non-Linksys products due to its lack of an IEEE standard
e) Enter a passphrase** that is different from the SSID. Try to make it alphanumeric; instead of just security, use security12345, then click the Generate button.
f) After the key has been generated copy the key into a notepad document and copy that file onto a floppy.
g) Click Apply then Continue
h) Close the window
i) Click Apply
Posted on Nov 13, 2008
    Scholar:
  • 132 Answers
If you're having Wireless connectivity problem, you can check the wireless settings especially the wireless security enabled in the router. To check the wireless settings in the router, you must access the router's setup page by launching IE from a computer that is "phyiscally" connected to the router, and typing 192.168.1.1. That is the default IP address of your router. Then, a window will pop up asking for a username and password. By default, there is no username. But the password is admin. Once you're in the setup page of the router, you will see the WIRELESS tab. Click on it. Check for the wireless network name configured in the router. Then, there is a sub tab under WIRELESS which is called, Wireless Security. Click that tab and you will find the wireless security enabled in your router. You will also find the network key that the wireless computers should have. In order to connect to the router.
In your Apple computer, open the wireless utility and check the available wireless network it can detect. You look for the wireless network name set in your router. Connect to that network and type the needed key.
Please update me with this and hope this helps you!
Want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
Even with the password, i cant connext to internet, but I CAN connect to the router (which isnt linksys). only when router isnt password protected can I connect to internet as well
You may have to settle for WEP passcode or none at all. The older technology may not understand any type of encryption. An alternative means of protection for you may be something called mac filtering. You will have to do the research. Good luck.
Mar 26, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
Wrt400n connects via ethernet cable, but won't talk wireless
you said every thing that connects with the ethernet is working. that means the wired part of the router is working. check the wireless settings of the router. Open the set up page of the router on the main computer. connect the main computer to the router with the ethernet cable.
change the wireless settings of the router.
WRT400N is a dual band router ( 2.4 GHZ and 5 GHZ)
You can create 2 different wireless networks. Make sure that the names (SSID) will be different for both the networks. For 2.4 GHZ change the standard channel to 6 and save the settings.
Go to wireless security and set the security mode to WPA Personal. set up password for the wireless network. You can use the same password for both the networks. Make sure that the Wireless MAC address is disabled.
Now try to connect to the new wireless network. and see what happens.
Click here for more information about routers
Mar 12, 2010 | Linksys WRT400N Router
Linksys Routers lose setup
I Had to replace a Linksys for a client because every time was a power outages the router was losing the setup. So try unpluging the power supply.
Jan 06, 2010 | Linksys Wireless-G Broadband Router
Want to password protect my wireless router
check out this link to solve your problem: http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3967
Mar 10, 2009 | Linksys Wireless-G WRT54G Router
How do I password protect my Linksis WiFi
STEPS to enable wireless security.
1. Please open Internet Explorer and type http://192.168.1.1
2. Leave it blank for username, type admin for password
3. When you have the setup page, click on Wireless tab, then click the sub tab Wireless Security.
4. Choose WPA-Personal for the Security Mode. Type in a password on the WPA Shared Key box (minimum 8 characters)
5. Click on Save Settings at the bottom. All set
Note: The password on WPA-Shared key is your wireless security password.
Jan 19, 2009 | Linksys Wireless-G Broadband Router
Protection on my Mac
Given that you have setup the Internet connection on your router, encrypting the wireless security will be fairly easy for you. Just follow these steps.
1. You should use you PC or MAC that is connected directly to the router via an ethernet cable. You can use PC or MAC, which ever is connected directly to the router (Connected thru cable not wireless).
2. Open Internet Explorer / Firefox (PC) or Safari / Firefox / Internet Explorer (MAC), then go to the address bar and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Leave the username blank and type admin as the password (**If that will not work, (Enter admin for both the username and password)
3. You should see the Setup page shown below :
4. Click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use your name or last name, or any name that you would like, because that will be the name of your wireless network, that will be the one that your wireless computers will detect) then click on Save Settings and then Continue when the Settings are successful dialog is displayed.
5. Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 64 bits 10 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. It Will generate 4 keys (Key 1-4). You will use key 1 as your password.
6. Finally click Save Settings and then Continue when the Settings are successful dialog is displayed.
7. Now let your wireless PC scan for available wireless networks, find the name of the wireless network that you have specified earlier for SSID then connect to that network. Of course since the network is password protected, it will ask you to enter a password, this is time that you will enter the network key (Key 1 - password).
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Router administration access
Hi Neomonkey,
It seems like you have a very big problem. If you are successfully connnected to the wireless router, you can check the the ip address of the router by doing an ipconfig in command prompt, check the default gateway and try to access using IE browser. The next problem is accessing the router when you are prompted to enter the username and password, the default is username: admin password: admin, depending on the model, if it is customized, you will have to reset the router to access it and configure the mac filtering or enable wireless security to deny the person who is taking up your bandwidth. You dont have to access the Paradyne modem to configure everything, if you want to find out if it is running DHCP, you can connect a PC wired(straight UTP cable) with all the network settings at default and check if you can get an ip using ipconfig with the command prompt. The main thing here is to reset your wireless routers to factory defaults(use the button at the back) to re-organize your connection and setup a security for unwanted users.
Inform me if there are other questions or clarifications you need regarding the problem.
Thanks,
Mrvin
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
I can only connect thru my router when hardline connected. Cannot connect thru wireless. wrt310n router
On the computer wired to the router.
1. Open an internet explorer browser
2. Go to 192.168.1.1
3. Leave the user blank then "admin" for password unless you changed it.
4. Go to the wireless tab Check the wireless settings If the Wireless network name is Linksys change it.
Cilck save settings.
Go to the subtab wireless security.
Change the security to WPA Personal
then for passphrase put in a password 8 chars or more.
Click save settings.
5. On your computer use the wireless connection to connect to your network name then enter your password
If that does not work or if you have difficulty with the directions just call linksys support 8003267114
Aug 18, 2008 | Computers & Internet
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
182 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
