Question about Olevia LT37HVS 37 in. LCD HDTV
Can't remove blue PIP (?) section in lower RH corner
I have an Olevia 37" LCD TV and I guess I'm just getting out of touch with all the new bells and whistles. Two issues:
1) I haven't played a DVD on the player hooked up to it in about 6 months because I can't remember how. I try everything on the remote and it's just not intuitively obvious to me.
2) Somehow, a blue rectangle (about an 1/8 of the overall screen) appeared in the lower RH corner of the screen and I can't figure out how to remove it. Very annoying. Help!
When I got HD service from TW Cable, I was told my Olevia remote would not work and I had two remotes (one from TW and one for Olevia). Now I have a universal remote from TW and I can't figure out anything!
  • sendtoalice Dec 09, 2008
    I think the answer is somewhere in the 'menu' selection since I have the same problem after 'tinkering' with the menu and cannot seem to undo the pip either.
I have the Olevia TV with RC-LTU remote, To get rid of PIP just press the (VIEW) button twice.
Posted on Aug 05, 2009
Regarding your issue #2 (blue rectangle), this is most likely the "Picture In Picture" (or PIP) feature. I have the same TV and a couple times, when fiddling with the remote, I have activated PIP. Problem is, despite there being a few PIP-specific menu options, there is no apparent setting to disable PIP once you activate it.
One way to deactivate PIP is to do the following:
1. Using the Olevia remote, click Menu
2. Click the up arrow button until the "Setup" option appears
3. Click the "Enter" button to select Setup options
4. Click the up arrow button until the "Factory Settings" option appears
5. Click the "Enter" button to select "Factory Settings"
(at this step I have to wait about 10 seconds for the Factory Settings menu to appear...be patient)
6. When the Factory Settings popup appears, you can use the down arrow button to select the Home option, then click Enter. Understand that doing this may remove some custom settings you have set, but it does remove the PIP.
(Also, before deactivating PIP you can use the PIP menu options to change the inputs for both the big and small rectangles, thereby utilizing the PIP function if you so desire.)
I am frustrated that the manual does not cover the PIP function in sufficient detail, but not as frustrated as the fact that this TV does not offer a code that works with my Comcast remote (and I've tried all the codes provided by others, to no avail). Pretty good TV though.
Posted on Jan 03, 2009
Can u help me I'm trying to fix my dad's old tv he gave me
Take it to repairs, or call the manufacturer. (well, the brand company)
Jan 26, 2016 | Olevia 37" 237-t11 1080i widescreen hdtv...
Olevia wont turn on
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Olevia 237T 37 in. LCD TV
How do you turn off picture in a picture
with the original remote which has a PIP button or buttons on it.
May 15, 2012 | Olevia 237T 37 in. LCD TV
Blue rectangle in lower right hand corner that wont go away
possible bad lcd. bad cof or chip on film. refer local service tech or contact mfg for lcd recall. hopefully its not damage from kids playing wii and one of the hand controls slipped out their hand and hit the screen.
Aug 24, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Blank Blue square on left hand corner of the screen ??
It might not be the same issue, but we had a blue square in the upper left hand corner of our hanspree. To fix it, either press the button headed 'pip' or go into menu, down to calibration and then uncheck the box titled 'pip' there. I hope this sorta yours as it did ours.
Nov 10, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
Small blue box in lower corner that wont go away
If you have pip or picture in picture, it may be active and set to a source that has no signal which would give you a blue screen.
Sep 12, 2009 | Olevia LT32HVM 32 in. LCD Television
How do I get the pip working on my tv?
Remember, you need 2 inputs to view PIP. If your set has 2 tuners you need to change to input2 in MENU. If you don't have 2 tuners you need to connect the other device using AUX or Video 2. Please rate.
please rate!
Mar 26, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Power problems
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
Sep 29, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
1,809 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
