Question about Fuji FinePix S602 Zoom Digital Camera
Camera won't turn on
No power even with brand new batteries. is there a separate system battery?
  • estepniak Feb 26, 2009
    My fuji fine pix s602 lost power when i pluged in ac power adapter in dc 5v socket . Gene
  • yfparch Apr 21, 2009
    i used the rechargeable batteries, Ni-MH1600, 1800, 2300, 2500 or 2700 mAH 1.2 v. Not each time i could take a picture after i recharging the batteries.
    Champion:
  • 225 Answers
Either your camera board is dead, or you are not using the right batteries. There are 2 types of AA batteries on the market today. One type is the normal 1.5V batteries. The other is the special lithium batteries that run a slightly higher voltage, usually about 2V. Many camera owners do not know this fact.
Posted on Nov 13, 2008
My Samsung WB100 turns off after switch on. Got new batteries and same problem plus 'old' batteries are still good even though camera said they needed replacing after a few days minimal use.
Make sure you are using name brand high quality batteries and not some generic from China. Camera require a great deal of power to boot up.
Jan 25, 2013 | Samsung Wb1000 Digital Camera
Kodak c340 won't turn on
Hello Carol, Are these batteries new and name brand ? It sure sounds like low battery power, Those cheap batteries found in some stores do not have the energy to boot a camera even when new out of the package. The camera has a very high demand to start up. I own several cameras that will not turn on with brand new cheap batteries.
Best Regards, Russell
Oct 28, 2012 | Kodak EasyShare C340 Digital Camera
Won't turn on
possible battery problem. look at battery contacts. clean w/ pencil ereraser or small scraping devise.GENTLY, on battery and camera.
possible dead battery even if new.even if you buy a new battery, clean ththe contacts an battery and camera.
Sep 25, 2012 | Kodak EasyShare DX6490 Digital Camera
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
Aug 01, 2012 | Kodak C183 Digital Camera
Nikon S8100 digital camera won't power on even with new battery.
1_ recharge the batteries or replace
2) clean the contacts batteries with contacts cleaner very well with carefully
3) see if the battery is loaded in WRON direction
4) memor card slot/battery cover is open.
5)poor contact between camera and battery terminal adjust the contacts and clean.
God bless you
Jul 31, 2012 | Nikon S8100 Digital Camera
My olympus tg 310 is stuck with the lens open and won't come on at all even when a fresh battery is installed
If the camera is within warranty, return it to where you bought it. Common fault with a few different brands, to do with a lens open sensor within the lens assembly itself. Maybe allow the camera to dischage without the battery for a few hours and see does it power on with a new battery. Also chack the battery, if it has bubbled it a dud, and check the battery contacts within the battery compartment.
Jun 05, 2012 | Olympus TOUGH TG-310 Digital Camera
I put new batteries in and the green light turns on but then it shuts off and deosnt turn back on
Often I have found with modern digital cameras of all brans is that generic batteries no longer have the power to made them run, so even brand new generic batteries will not start the camera.
the solution is you always must buy the expensive brands or invest in a rechargeahle battery system for AA batteries, which mine takes the best. So try that out. I think u will find that money does make a difference
Jan 16, 2010 | FUJIFILM Finepix A200 Digital Camera
IT HAS BRAND NEW AA BATTERIES IT WILL TURN ON BUT THEN TURN OFF
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though brand new and right out of the package, they may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Modern rechargeable batteries (I'm not talking about old NiCad's, those are awful) can hold over five times the amount of power of an old fashioned alkaline battery. Also keep in mind that rechargeable batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Oct 26, 2009 | Cameras
Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Jun 28, 2008 | Kodak EasyShare Z740 Digital Camera
Fuji FinePix S602 Zoom Digital Camera Logo
387 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
