Question about OKI B4200 Led Printer
Oki B4200 Error lights
We have a number of b4200 printers in our office and have had 2 of them in the last few days stop responding. The error cycle is this: Printer turns on (all lights flash on), Its does the engine test and turnes the gears, At the end of the engine test the lights flash again and then the Error and feed lights flash for about 5 seconds and then it resets and starts over again. This will continue until you give up. The status monitor just says "Communication problem" all the time, the computer is plugged in using the USB connection. Ideas?
2 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: oki c5400 communication error
This means that the interface type settings are incorrect in the Printer Menu and might be due to trying to use half duplex comms instead of full duplex, you are trying to use TCP/IP when the printer has this option turned off. It could even be as simple as something wrong with the interface cable being used or a mismatch in USB1.1 to V2.
Posted on Sep 11, 2009
try switch off, unplug, hold up and down & reset button at the back, swith on
Posted on Sep 13, 2011
0 characters
1 Points
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Amber light on oki c3300 continues to flash and printer will not print
Here's what the owner's manual has to say:
Error status (Amber, blinking): you cannot continue to use the
printer. Intervention is required to recover from the error. Fatal
errors are irrecoverable and require a service call.
Blinking 1 (2S cycle)
An error has occurred but
printing can continue if you
press the ON LINE or CANCEL
Blinking 2 (500mS cycle)
An error has occurred. You
need to replace consumables
or remove jammed paper, for
example. The printer then
recovers from the error and
printing becomes possible
Blinking 3 (120mS cycle)
A serious error has occurred.
rebooting or a service call is
The Status Monitor in Windows provides a readable description
of the printer status corresponding to the indications of the
LEDs. In Mac, the printer driver provides status information
once you have sent a document to print. In Windows, if you
have the Status Monitor Preferences set to Pop up on alerts,
this readable message will be presented on screen whenever
an abnormal condition occurs.
There's no further information. Sorry.
Jul 19, 2011 | OKI C3400n Laser Printer
If you are having issues with your system's print spooling services. You can try this steps:
Hope this helps!
Good Luck!
Mar 14, 2011 | OKI B4200 Led Printer
Jan 30, 2009 | OKI C3200n Led Printer
Oki Data c5500
If you buy a printer with a 3 year warranty then your printer is covered for 3 years. if, under the warranty, the manufacturer decides to give you a replacement rather than fixing it then your warranty continues for the 3 years from the date of purchase. I know for a fact that this is how Oki operate in the UK. Call their service department in Slough again and I am sure they will sort your printer under warranty. All you need to have ready is the serial number and they can check your warranty entitlement. If the warranty was not provided by Oki then I would be off to trading standards.
Sep 10, 2008 | OKI C5500n Printer
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
Jan 08, 2008 | OKI C9300 Led Printer
Problems with Oki Printer and Toner Sensing
Yup Dodgy refill cart without require chip to identify itself to the printer or cart not suited to b4200/4250 , get a real oki toner from your country that suits exact model.
here is code for required product
Oct 31, 2007 | OKI B4250n Laser Printer
There is a red light flashing
From the OKI site, I found this information. My problem is a Flash 2 Blink, which is a problem with the cover or minor error, whatever that means. I can't figure out how to fix it. Any suggestions greatly appreciated!
Flash type Ready LED (Green) Manual feed LED (Amber) Error LED (Amber) Meaning Flash 1 -- slow blink X ecblank.gif ecblank.gif The printer is processing data when printing has been suspended. ecblank.gif ecblank.gif ecblank.gif X The image drum required changing or toner is low. Flash 2 -- blink X ecblank.gif ecblank.gif The printer is receiving and processing data during printing or the printer is resetting itself. ecblank.gif ecblank.gif X ecblank.gif The printer is requesting manual paper feed. ecblank.gif ecblank.gif ecblank.gif X There is a printing error, problem with paper or a cover open. ecblank.gif X X X There is a minor error with the printer. Flash 3 -- rapid blink X X X There is a major error with the printer.
Oct 27, 2007 | OKI B4250 Led Printer
Oki C5200n 002: Fatal Error
I too am having this problem, I suspect it started after installing our new FIOS router, so it could be network related. It's possible the number could be referencing an internal memory number.
Aug 30, 2007 | Printers & Copiers
Error number 172
the problem is on the fuser unit, ther thermistor on it is damaged.
Jun 02, 2006 | OKI C9300 Led Printer
OKI B4200 Led Printer Logo
213 people viewed this question
Top OKI Printers & Copiers Experts
Level 1 Expert
Dominion Computer...
Are you an OKI Printer and Copier Expert? Answer questions, earn points and help others
