Question about Whirlpool RBD305PD Electric Double Oven
After usung the self cleaning function the oven no longer works
I have a 5 year old, Whirlpool, double, electric oven. This morning we turned on the the self cleaning function and left for work. When we came home the top oven was clean (only the top oven has the self cleaning function) but the oven was no longer working. The digital clock was off, the light didn't turn on and and we couldn't turn on either oven. I checked the circuit breaker and it was fine. We have used the self cleaning function several times in the past without any problems. Is there some internal reset button that was tripped or fuse that was blown? Why would the oven just stop working?
  • 4 more comments
  • heatherj423 Jan 15, 2009
    Where's the plug? and how do you check for correct voltage?
  • Anonymous Jan 22, 2009
    I have the same issue - in this case both ovens have the self-clean function and the bottom oven won't work after cleaning. The display, light and fan are all functional, but neither the top or bottom will heat.
  • knoxtim Mar 03, 2009
    Self clean for the upper oven started, everything was going fine and when I checked the oven a couple of hours later it was dead. What's worse is that it has locked me out. There is no display on the board or anything and I can't open the upper door because of the lockout mechanism. What now?
  • Anonymous Mar 17, 2009
    I've got ~120V into the PC board inside the oven, but no lights.
  • mrgaylert May 17, 2009
    I have a self cleaning top oven also and went out with only 40 minutes left on the self clean. When I got home the oven is black no power anybody try the power source for 10 minutes?
  • Anonymous Mar 19, 2014
    oven is under counter and 25 years old
  • 509 Answers
What can be checked now is the door lock mechanism. Sometimes during a lock out which prevents you from opening the door. They will go out during a clean cycle. Now the wires from this solenoid need contact some supply ground to oven temp relay some supply power ,which helps the relay points activate which activates the oven heating elements. Although it is possible for the oven temp relay to have gone out it is just unlikely. I am sure if you start a continuity test on the oven door lock following the wires back to the control panel and oven relay you will find you problem in this area. Remember to rate my solution it is how i receive my achievements. Thanks in advance. Also sometimes Unplugging the unit can release some sticking or inoperative solenoids and relays. Good Luck and if you need my assistance further feel free to ask for me.
Posted on Apr 14, 2012
The quickest easiest solution is to call an appliance repair place and have them come and fix it. I have had the internal fuses blow on on three separate occassions, all caused when the self cleaning function was used. Another solution is to place an inline circuit breaker to the fuse so the breaker will pop first rather than blowing a 40 dollar fuse. The circuit breaker should not be greater voltage or current rating than the fuse if you choose to go this route. Otherwise, its pay the repairman to replace it.
Tom B
Posted on May 28, 2009
    Scholar:
  • 68 Answers
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Posted on Nov 13, 2008
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
The oven won't lock shut for cleaning
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
How do you replace the thermostat?
You will need to pull the oven out of the wall and remove the back panel. The thermostat is located behind that panel and held in by two screws. Whirlpool makes a wire harness kit that can be installed which allows the fan to run longer preventing this problem from happening.
Dec 04, 2007 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD305PD Electric Double Oven Logo
542 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
