Question about GPS
Garmin can't find maps and is also says press teh dots what does this mean
  • Anonymous Apr 23, 2009
    I have the same problem. Garmin Nuvi says it cannot find maps and it won't let me put in addresses or anything.
Ho aquistato un nuvi 255. E lo schermo e bianco e scritto PRESS DOT. cosa posso fare?
Posted on Jan 03, 2010
Garmin nuvi 200 problems- I press streets icon ----it comes up (NO DATA AVAILABLE).
Make sure that your map is enabled with a check mark on the map info screen. If the map info button is grayed out, then this means that your map is missing.
Jul 08, 2013 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 205w gps black dot problem
Please be more specific. There is a calibration screen where black dots are shown and you press them to calibrate the touchscreen. Is this what you mean? If you press them and nothing happens, your touchscreen may have failed and needs to be replaced.
May 27, 2013 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 1350 LMT turns on to a calibration screen. it will not go to the maps home screen. how can i fix this
There should be a black dot to press on the calibration screen. Keep pressing the dot as it moves around the screen, you may need to press very firmly and use a stylus until it says calibration complete.
This usually occurs when a unit is dropped or left in extreme temperatures or jammed it a glove box or console with things jammed against the screen. It could also occur if you are touching the screen as you start.
Thanks for using FixYa
Jul 27, 2011 | Garmin GPS
NUVI 255W. i UPDATED MY SOFTWARE ON THE GARMIN SITE NOW ALL MY MAPS HAVE DISAPPEARED SO THE SCRENE MESSAGE SAYS, HOW DO I GET THEM BACK.
1. It's most likely that the map has become unselected.
  • Press TOOLS (The spaner icon on the bottom right of the screen showing WHERE TO and VIEW MAP)
  • Press SETTINGS (The spanner icon) or LOCALE if your model doesn't have a settings icon.
  • Press MAPS
  • At the bottom of the screen press MAP INFO
You'll see the name of any maps installed and there should be a tick beside them if they're selected. If there's no tick press the map name and it will tick them. That may solve your problem.
If that doesn't solve your problem the map may be locked. You can get details of how to unlock your map at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's more information there than you need so you can strart at paragraph 2.
In the unlikely event that there's no map name when you press MAP INFO it would mean that the map has been deleted and needs to be reinstalled.
To reinstall the map;
  • Connect your satnav to your computer with the mini USB lead
  • Go to www.garmin.com, click on myGarmin and log in.
  • Click on the myMaps tab at the top of the screen.
  • You'll see the name of the maps you have on your satnav and under the name in blue writing the word "details"
  • Click on "details" and it will take you to a screen where you may be able to download the map again depending on how long it has been since you last downloaded it.
If you cannot download the map again you'll need to contact garmin. You can get their contact details at http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 12, 2011 | Garmin GPS
Hi, I have a Nuvi 255 (205 series) gps, three years old. Last week the screen went blank, came back grey with 'crosshairs' and a black dot in the middle indicating 'press here'. I did so and the dot moved...
Graham - what your describing sounds like you somehow managed to erase the street level maps and POIs in your Nuvi.
If you connect the GPS to the computer with your USB cable, you should at the contents of the Nuvi directories and find a file called GMAPPROM.IMG or GMAPSUPP.IMG. These are the street level map files. Generally, these are found in the root directory of the Nuvi - or if yours has / and you use a memory card slot for maps - find it in the /GARMIN directory. GMAPPROM.IMG is the name of the first map set and GMAPSUPP.IMG is the name of the supplementary or second map set (if you purchased & installed one). You will likely have only one of these files - and may be named either. The size of this file depends on the area and age of the map. Current maps of the entire US run over 1 GB in size. If you do not have any maps named GMAPPROM or GMAPSUPP, you will not see any street level maps.
Something happened to delete the maps. Garmin will probably NOT provide free replacement maps for you, unless under warranty. If the devices is trashing maps and other files, you probably want to replace the unit under warranty or not. Garmin will, upon return of your old Nuvi - replace it with a factory refurbished unit with the latest maps installed, for $79. You can take advantage of this service by following this link to Garmin Service.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 255
Hook your Garmin into your pc -using the USB cord provided with the kit- run the disk -then go to GARMIN dot com and look for maps for your unit. There is a charge. 1687c58.jpg
May 02, 2010 | Garmin nuvi 250W GPS Receiver
Garmin Nuvi 205 can't unlock maps
First, check to make sure the map file is there. The file name is gmapprom.img. It's located in the Garmin directory. It should be 1GB in size. To do this you need to connect the Nuvi to a PC with a USB cable.
Next, please tell me what year of map you have on your unit, 2009, 2010, etc.
Them, email me your units internal serial number. Its a 10 digit number (not the number on the outside). The number starts with a "3" and can be found by pressing the tools button, then system and then "about".
Please email me at sharcnet-usa AT sharc DOT NET
- Jim
Mar 25, 2010 | Garmin nuvi 205W GPS Receiver
Maps disapeared from my garmin for no reason!
go into settings, then map, then map info see if box is ticked if not tick it, then return to where to and see if countrys name appears the select country
Dec 04, 2009 | Garmin nuvi 205 GPS Receiver
GPS Logo
823 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
