Question about Panasonic CT-27G34 27" TV
Screen tuns black after 15 seconds and comes back after about 15 minuts
I have a panasonic TX-25LK10C When we turn on the TV we get a normal view for 10 till 30 seconds. After that the screen turns black. This black screen stays for 5 till 30 minuts, then the normal view comes back at ones. After this the TV works normal until the end of the evening. Using vidio or dvd gives the same effect. Some times the view is already black when the TV turns on. Then the normal view will also come back after 5 till 30 minuts. Does anyone has clu what the problem is?
  • 398 Answers
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Posted on Jun 26, 2007
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Tx-26lxd70a tv wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 12, 2012 | Computers & Internet
Onkyo TX-SR706 Setup Display Problem
For adjustments to receiver you can always run a component or composite cable to your plasma tv. After adjustments are made just return to HDMI input.
Feb 24, 2010 | Audio Players & Recorders
Problem With KENMARK flat Screen TV - BLACKS OUT
you do not give the model number for a better diagnosis
the most common cause of this problem is the invertor or at worse the screen its self.
If it is a lvd 163 you can purchase a new invertor from sales@tvs-services or call 01245392539
Feb 14, 2010 | Zenith IQC50H95W 50" Rear Projection...
I have a Panasonic TX 15LT2 TV, after about 15
the small signal panel needs to be replaced.
[main module]
take you tv to a factory authorized service center..
Nov 09, 2009 | Panasonic TC-22LT1 22 in. LCD EDTV
The TV cuts off frequently. The screen is blank & no sound.
It is probable you have a poor soldered connection on the power supply board, hence the erratic timing of the TV going on & off. If you are competent with a soldering iron look for dry jointed soldering on the board. If not have a service engineer take a look at it for you.
Jun 24, 2009 | Panasonic Televison & Video
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Picture comes on for 2 seconds then tuns to black screen Sound ok
Hi!
This more then likely a back light inverter board issue! It can be intermittent or just black an non responsive.
Feb 18, 2009 | Televison & Video
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
Panasonic CT-27G34 27" TV Logo
227 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
