Question about Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower
Deck removal how do I remove the mower deck to replace belt
  • 36 Answers
If memory serves me correctly it is just disconnecting the rods and I think there were a few large springs also. If you tear it down that far you may as well check pulley bearings too!
Posted on Nov 13, 2008
5 Suggested Answers
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
bargainbin2
  • 123 Answers
SOURCE: replacing deck belt
Here ya go.
Posted on Aug 26, 2009
mickey813
  • 472 Answers
SOURCE: Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
Posted on Oct 08, 2009
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
How to replace drive belt on sears 247.28904
If you have an Owner's Manual,it will inform you,in the Manual how to go about removing and replacing a tractor drive belt. There is a decal under the left or right foot board,informing the operator how to install the belt correctly. This is a long belt.that runs from the pulley on the Transaxle to the upper pulley on the bottom of the motor. This could be a hard repair to do,if the mower deck is installed. I have removed and replaced this belt,by lowering the mower deck all the way down. I would recommend,that you remove the deck,much easier.to replace the drive belt. This is also is in the Owner's Manual.under," How to remove the mower deck". Hope this answer your question. Sincerely,Brad Locke DTD. 12/03/15
Aug 06, 2013 | Sears Craftsman Tractor Mister
I have a Sears Garden Tractor with a 48" mower deck. By working in long, thick grass I broke the mower belt -- not the one that transmits power from the engine, but the belt that sits in a pulley on...
I believe that tensioner pully has to be loosend up and moved.
Here are the instructions for this.
  • Place the deck in the lowest position using the hydraulic piston (if applicable) or the manual cutting-height adjuster.
  • 2
    Remove the deck-to-PTO belt from the PTO by releasing tension on the idler-arm pulley. This is a spring-loaded handle that turns in only one direction by hand and relieves the tension on the belt. Slip the deck-to-PTO belt off the PTO pulley after the tension is relieved.
  • 3
    Remove the deck from underneath the mower or tractor.
  • 4
    Locate any belt stops and loosen them with the ratchet wrench and proper socket. Belt stops are located on the deck and are the small metal brackets that guide and secure the belt to the pulleys so it will not jump off when under heavy use, or stretch from normal wear.
  • 5
    Remove any pulley covers by removing the retaining screws using the ratchet wrench and a socket.
  • 6
    Loosen the idler-pulley retaining bolt (located on the underside of the mower deck) to replace the deck-to-PTO belt. Removing the bolt is not necessary. Loosen the pulley enough to wiggle the belt free from the pulley and remove and replace the belt.
  • 7
    Remove any arbor covers (if applicable) that conceal the arbor pulleys by removing the retaining screws with the ratchet wrench and a socket to replace the mower arbor belt.
  • 8
    Locate the tensioner pulley on the mower arbor belt to replace it. Loosen the tensioner pulley bolt enough to slide it and release tension from the belt. Remove the belt from the arbor pulleys and replace it.
  • 9
    Slide the tensioner pulley back leaving about 1/2-inch of play in the belt and tighten the bolt. Reverse the procedure to put the rest of the mower deck back together and reinstall on the mower or tractor.
  • May 10, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    Mower deck clutch cable removal (model 917.28722). Detail provided in manual does not seem to match product. Need to remove this in order to remove deck and replace belt. Belt has squealed since new.
    You should not need to remove the deck or the clutch cable just to change the belt.
    • ensure mower clutch lever is in the off position
    • lift the front of the tractor approx 24 or more inches.
    • lower the mower deck as far as it will go
    • locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
    • release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
    You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
    If this is helpful please vote yes, Thank You!!
    Aug 28, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
    What is the easiest way to remove the deck to change mower belt.
    Your listing doesn't specify the model number of your tractor. But I found a users manual for a 24HP model 917.28936 here and perhaps this is yours, or similar.
    This model uses a single mower drive belt (some tractors use two separate ones) and you do have to remove the mower deck to replace the belt. The procedure is in the manual. Hope that helps.
    Jul 02, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
    I am trying to find out how to replace the mower belt of my 2006 LT2000 23hp Craftsman lawnmower
    Replacing the belt is easiest if you drop the deck. There are roughly 6 pins you must pull (refer to sticker on deck) including the engagement cable. Pull the deck from under the tractor and remove the plastic pulley shield from the left side. Remove the belt and replace the same as you took off and re-attach the deck to the mower.
    May 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    Install belt on toro mower model 70041
    For removing/replacing the deck belt, the general method is:
    1. turn off engine, remove key and set parking brake
    2. disengage blade by putting blade engage lever into off (disengaged) position
    3. lower the cutting deck to the lowest position (closest to the ground)
    4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
    5. remove and replace the belt
    NOTE: it's not necessary to completely remove the cutting deck.
    Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
    For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
    If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
    Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
    How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
    you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
    Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    Owners manual
    Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
    Components of a typical riding lawn mower. (click to enlarge)
    It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
    A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
    To remove the mower deck:
    To adjust the drive belt:
    4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
    Apr 12, 2009 | Garden
    Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower Logo
    669 people viewed this question
    Top Husqvarna Garden Experts
    Phil Walker
    Phil Walker
    Roland W VanLue
    Roland W VanLue
    Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
