Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I'm trying to hang my flatscreen tv above fireplace and need help
This area is brick. Are there special needs to attach it to brick? The gas firebox has glass doors. Is there a certain special (standard) heighth to view a flatscreen? Will the heat from the fireplace effect the tv? Are there any other special requirements for this installation?
  • 374 Answers
Wendy,
When attaching your wall mount to the brick you should use a metal lag shield designed for masonry. These can be found at the local hardware store but i would carry the mounting bracket with you so that you can ensure that you get the appropriate size of fastener that will pass through the bracket. As far as the heat goes, it really depends on the amount of heat the system will be subject to. Some fireplaces are more for decoration and produce very little heat above the mantle area. Others that have blowers on them or are left with the doors open genrate considerable heat.
I would not advise the mounting of the tv above the fireplace in my professional opinion. The cooler you can keep electronics - to a point- will greatly increase the service life of the appliance.I hope this is of assistance to you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
Posted on Nov 13, 2008
Discontinued Majestic dvhvac36 fireplace. crack on top of firebox (combustion chamber?) between 2 round "padded" filters? Will need to be replaced. wondering if anybody had the same situation?
i would say it would be a common issue as unit firebox
ages heats and cools ..so often
if you cant buy the casing or
find a used unit for sale with a good casing
depending on which material in the casing is made of
if metal or aluminum
welding the crack or a patch repair
may be possible because it is at the top of the unit
if cast iron needs a special pre- heating method of repair
or a new casting made
found this link out of new york area
DVHVAC36
Oct 13, 2016 | Cars & Trucks
I would say it would be a common issue as unit firebox
DVHVAC36 DVHVAC36
Wind blows out the gas logs
I am sorry, but there is insufficient information to give a proper answer. If it is a vented logset, is it in a vented indoor firebox/fireplace or an outdoor fireplace?
Jan 11, 2016 | Majestic Fireplaces Majestic VWF24NMD 24"...
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I just bought a 46 inch SAMSUNG LED HD TV from Best Buy and will be mounting it on a brick wall above the fireplace. The fireplace has gas logs with a an 8 inch mantle that extends 8 inches off the...
it is not safe to mount the TV 8 inches above the mantle.
Secondly, the heat will certainly be a danger if the TV is mounted above the mantle.
I would advice you look for another position to mount the TV.
I hope the above is clear.
Regards.
Sep 27, 2011 | Televison & Video
Blade on fireplace heat o lator appears to be turning the wrong way. Heat does not come out of the top of the fireplace. What do I do to be able to take out the heat o later and reverse the fan?
Roger. it depends of whether this is a Gas Fireplace or a Wood Burning Fireplace?
If it's a direct vent gas fireplace, the blower was installed incorrectly. To access the blower, you will have to dismantle most of the interior of the firebox and the burner tray (Interior floor of the firebox). This will involve disconnecting the gas line from the burner. The blower is on the floor of the control compartment and is attached to the rear wall of the control compartment. Whoever installed it, has it aimed in the wrong direction. Which is can of hard to do, since there is an arrow on it, pointing in the UP direction. Once you unplug it, you can take out the sheet metal screws that hold it in place, and it will be quite obvious which way the exhaust should face. Which is UP.
Now that I've told you how to do all of that, I must be totally honest, by telling you, the blower will not increase it's efficiency. Your Direct Vent Gas Fireplace is rated as a Decorative Gas Appliance only. It is not heater rated. In fact, 80 % of all the heat goes out the direct vent. The only real heat, is generated off the glass, once it's hot.
So now, you get the chance to make the decision. With all that's involved, is worth changing the blower and not really gain anything?
If you have a wood burning, brick fireplace Heat-a-Lator, just turning the fan motor around, so that it's pulling air into the chamber, will solve the problem.
I really hope all of this has helped you. If I can be of further assistance please let me know. Thanks.
Jul 14, 2011 | Heating & Cooling
Where does the FBK200 blower go in the Marco fireplace
As you are aware the Marco Fireplace Co is no longer in business. However, the blower model # you listed is a DESA/Vanguard part number. In any event, it may work.
The blower goes in the lower compartment (probably louvered) under the firebox. It is then attached to the rear wall of the compartment, with the blower output facing up the back wall of the firebox. There should be an arrow on the blower housing indicating which way it should point.
If your firebox is already wired for a blower and has a duplex receptacle in place (for the blower to plug into), you're in business. If it doesn't I highly recommend that you install one and not try to hard wire the blower.
The blower, if purchased new, should come will all the hardware to mount it. If it didn't you can use sheet metal screws to attach it to the rear wall of the firebox. However, make sure that you put a rubber flat washer behind the mounting frame and then screw thru it into the firebox wall. This will help eliminate vibration and noise.
Hope this helps to get you started.
Feb 25, 2011 | Heating & Cooling
I have a valve on the wall with a Hearthmaster key. In the fireplace is a long tube with slits cut every 5". Is this a gas fireplace or what?
From what you described, it sounds like a homemade gas log lighter for a masonry, wood burning fireplace. The Key in the wall is to turn the gas on and off. With that said, no it's not a gas fireplace per se. It's used to light firewood. However, if you don't want to burn wood (with all the fuss, muss & dust. You may be able to install a 99.9% efficient, Vent-free Gas Log Set, by using the existing gas line.
However, it's not a case of one size fits all. You will need to know the following concerning the interior of your firebox: Width, Height, Depth (from the center of the opening to the rear wall of the firebox, on the floor of the firebox) and the Width at the back. And the final dimension (if you have a wood mantle) The distance from the top of the opening of the firebox to the bottom of the mantle shelf. If it's less than 18", Code requires a heat deflector hood to be installed to the top of the opening of the firebox, to direct the heat down and away from the mantle.
Generally speaking, I do not recommend this as a DIY project, If you decide to pursue this, contact a professional in your area that sells and installs Vent-free Gas Log Sets. That way, you'll be able to determine which BTU Output is suitable for your application. They're usually in the Yellow Pages under Fireplaces.
Two pieces of advice:
1. When it comes to BTU Output more is not better. Gas is a warm moist heat, that you'll feel very quickly and it's very comfortable. You actually can do more with less.
2. Avoid Ceramic Fiber Logs. They are very fragile and do not hold heat and radiate it back into the room. Stick with Refractory Concrete Logs. They are heavy and very durable. They get hot hold heat and radiate back into to the room, even after the burner is turned off.
Everything I have told you is based on by 15 years in the hearth business.
Feb 02, 2011 | Heating & Cooling
We would like to mount our 50 inch Sanyo plasma tv above our fireplace. Is there a temperature limit we need to worry about and do compatable wall mounts have the hardware for brick/mortar?
As long as the set is mounted correctly, there should be no real trouble with heat.
The Mounts, are/maybe standard, however it is the fastening that will differ, if stone, brick, concrete then special fixings must be used, apart from that you will be all good.
Feb 01, 2011 | Sanyo DP50747 50 in. Plasma TV
Distance over gas fireplace
Both LCD TVs and plasma TVs get hot, though plasma TVs tend to be a bit hotter in my experience. Also, plasma TVs are going out of fashion.
A lot will depend on the construction of your fireplace. If it's brick it should insulate fairly well.
Either way, I would recommend a mounting solution that does not put the back of the TV flush with the wall. Get one that tilts. I would avoid the "arm" style ones as that will put additional strain on the mounting.
Remember to think about how you want to run your power and video cabling as well!
Apr 06, 2008 | Televison & Video
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
167 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
