AOpen F90 JS needs a new power/inverter board.
The board has gone out and I cannot find a replacement board anywhere. I've searched and searched and have attempted to contact AOpen multiple times with no luck and cant seem to find this board anywhere.
I was hoping maybe someone here knows where to find one. The model on the board itself is JT198AP 2202126501.
Thanks!
  • kloops Nov 13, 2008
    I've checked them all out and they all seem fine (non are bulging, nothing looks burnt). Anything I should look for or should i get a multimeter and start testing them that way?
    Champion:
  • 293 Answers
Hi...there,
Sorry...you're out of lucks! It's only available from the manufacturer. But you can repaired it yourself by replaced a few busted capacitors. Good lucks!
Posted on Nov 13, 2008
  • Cj T
    Cj T Nov 13, 2008
    Hey...
    You can't tell by just looking at it... you need a meter that read ESR / Low Ohms to test for leaked. Don't have one, then just replaced all the caps...
I've had my Hitachi 55" model #55VG825 TV for
As it is 7 years old, replace all the electrolytic capacitors at its main power regulator board. All of them might have value deteriated. If so, power supply wont get proper regulation. If you wish to get more details, check this link.
Apr 22, 2013 | Televison & Video
Is totally dead. First, I received blinking led, but right now, nothing. Si habla espanol, mucho mejor para mi, si no, puedo conitnuar en ingles.
Hi Eduardo,
First of all, thank you for contacting Fixya.com regarding on your TV problem.
I'm assuming here that your TV's model no. is TCP50S2. Most of the blinking LED on Panasonic TV's has a corresponding error code let say the led blinks 5 times(won't turn on), it is a 5 Volts malfunction either on the P board (power supply board) or on A board. Some of the blinking led error code are related to faulty electrolytic capacitor on the power supply board. It will dropped the normal working voltage of the power supply and will disable the unit. Faulty capacitor most of the time has a physical indication of fault like bulged/dome at the top and can be easily identify through visual inspection. Watch the video below for more info.
In your case, you've mentioned that the TV is totally dead set now, this is an indication of fault either on the P board or on A board but most cases I've encountered a faulty P board (power supply). I've suspected that your P board gone to multiple parts malfunction aside from the capacitor.
If you are going to DIY, I would advice you to check the output of the P board using a multimeter to confirm its condition. Once it has a missing voltage, replaced the entire board. Click it HERE for the P board's replacement.
Hope I helped you.
Have a nice day!
Ratings and feedback are highly appreciated!
Kind Regards,
Jdvillanueva
Dec 03, 2011 | Panasonic TCP50S2 50 in. TV
Polaroid model 3211tlxb sept. 2007.ec18 on the power board gets very hot and tv shuts down. i have replaced ec18 and q16 no help
Hi mrdink010,
I've checked my service manual collection but I don't have the copy on this model. I've also search it online and to my links of the service manual but I can't find one to view the schematic diagram of your unit.
The power supply gone to excessive heat due to over current flowing on its circuitry. This is caused by faulty parts like the transistor, IC's, diode, resistor, capacitors, transformer on its line that in most cases have a partial leak. This is hard to diagnose and needs the skills of an expert to determine which part gone bad. Usually this is not caused by one parts only but most of the time multiple parts gone to malfunction.
I would advice you to replaced the entire power supply board rather than troubleshoot this kind of symptoms because it will cost almost the same. Click this LINK(http://www.shopjimmy.com/polaroid-860-az0-mlt666amh-power-supply.htm) for the replacement. Double check the actual part no. of your board that is printed on the white sticker on the board itself before ordering online.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 29, 2011 | Polaroid Televison & Video
I have aopen board Model No is Mx46u2.i search alot but i did not fet its vga driver kindly provide me link or anyy circumtance where i get this... regard fahad kaif
here is it....
http://www.driverstock.com/AOpen-MX46-533V-driver-download/29-9-12776-93089/index.html
http://www.driverstock.com/stor/files/29/pub/driver/mb/sis/agp/agp_112.exe
Nov 18, 2010 | AOpen MX46-533V (91.89U10.061) Motherboard
The phone doesn't work every time I search for network it keep searching and freeze
Hi, there is possibility of the network IC gone bad and should be changes or there is bad contact of the Antenna to the board its good to check the contact .coz if there is poor contact of the Antenna network search will be poor
Jan 07, 2010 | Palm Treo 650 Handheld
I saw you answer a question about LCD screens going out
the capacitors are bad those are the only thing that need replaceing, the componenets on the board are likely fine
if you like we can arrage a deal and you can ship me the boards to repair them let me know
Nov 11, 2008 | Computers & Internet
Aopen vkm400an-s
Hi bones698, you can go to the link below & check the bios's listed for your vKM400Am-S board.
http://download.aopen.com.tw/Default.aspx
You will need to fill in the three dropdown windows as follows:
Motherboard
vKM400Am-S
Bios
I have gone over ever bios listed at AOpen.
There is one update for AMD Sempron Processor's. Version R1.01 Release date; 7/27/2004 Please double check your system at boot up for your version. Use the Pause/Break button on your keyboard to freeze your screen. This will give you the time needed to check your current bios version. To flash your bios go to pg. 40 in the manual.
Good Luck! Take your time.
Mike
Apr 03, 2008 | AOpen vKM400Am-S Motherboard
Aopen mother board diagnostic light lite up
if that problem...that motherboard is defective ...i suggest to buy a new motherboard that compatible to your processor and memory... i'll give a link of site to buy the part.....
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=1&from=R10&_trksid=m37&satitle=motherboard&sacat=-1%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=ZIP%2FPostal&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&fgtp=
Dec 17, 2007 | AOpen vKM400Am-S Motherboard
Computers & Internet Logo
457 people viewed this question
David Payne
David Payne
