Question about Danby 22 in. DDW396 Free-standing Dishwasher
Spray arm not working
I have been Having problems with my spray arm not working, have tried taking the arm of to clean and run vinigar through it but nothing works, Right now it is a hit and miss situation it works one day then only for one wash cycle. We may have left the unit on and the water supply was accedently shut off while the washer was left on for maybe a couple of hours. do you think I need speacial parts for spray arm.
  • Cobham Jan 01, 2008
    upper spray arm not rotating
I have to remove my spray arm and put boiling water down the hole and tghen it works
Posted on Sep 06, 2007
I have a GE GSD6660 (from 2003) dishwasher that is not cleaning properly. I've tried a few types of detergants, gels, powders. I've cleaned the inside by hand, I've ran cycles with vinegar and baking...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 18, 2011 | GE 24 in. GSD6660GSS Built-in Dishwasher
I have a Maytag MDB6100 dishwasher, 10 years old, has worked perfect until now. Now, the top dishes are still dirty when done. I discovered that no water is coming out of the top whirley-gig. The soap...
Here's a DIAGRAM of your pump system. If you can use the diagram and take it apart you can find the defective part. When the impeller runs it's supposed to pump water up the bottom and top spray arms. You may get wet looking but you need to see where the water is going if it's going anywhere. Also make sure the tower to the upper spray arm is clear and not stopped up. Look for cracks, water spraying in the wrong place or the impeller could be rounded off and not turning.
Feb 04, 2011 | Maytag 24 in. MDB6100A Built-in Dishwasher
Our Maytag dishwasher consistantly leaves a film/skum on glasses. We have reduced the amount of soap. We use cascade liquid. We have added a cup of vinigar to the wash. Still the glasses come out cloudy....
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Nov 04, 2010 | Maytag Dishwashers
I think my van has a clogged windshield nozzle. The wiper fluid comes out but doesn't even squirt high enough to hit the windshield.
First try to clean out the squirter nozzles.Take a very small wire, sometimes a staple works great, and stick it into the nozzle to clear any debris.Then try to spray it again.If this didn't solve the problem and the debris is cleared, then you either have a weak or blocked pump, which is located on the washer reservoir itself.Hope I could help!!! Rate me accordingly!! Thanks!
Oct 06, 2010 | 2002 Chrysler Town & Country
Top spray arms dont work.
Most likely you have debris blocking the holes in the spray arms. The spray arms can be removed and cleaned out in your sink. (blocked holes in the lower spray arm arm almost impossible to clean out)
Jun 05, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Dishes not clean powder not distributing - Jet Clean Flexi-Load
I have used this before and it works great! Dishwasher Majic. Sears' site is down I was going to post a link to it but I found this one instead. I work on all types of used dishwashers and It returns the inside to "like new". The short video link I am sending to you will tell you how to use it and I learned something myself by watching it...you can get it at wal-mart! Good Luck and write back with any additional problems!
P.S. Dont remove the spray arm when you use this. If you want you can remove the spray arm and spray some slightly pressurized water into the core of the spray arm to try to push out any buildup that will sometimes get in them and then run the unit with dishwasher majic and spray arms in place.
May 15, 2009 | Dishwashers
I have an equator PLS600 and I can't seem to get it to work. I have tried the WikiFix to help a stalled dishwasher, by adding water and vinegar. When I put on the wash cycle it does not run. Even with the...
Give the spray arm a spin to make sure it rotates. It should spin freely. If not, remove plastic spray arm clip, flip it over, replace it, and try again. Make sure holes in the spray arm are clear of debris. Spray arm must be clean for it to spin. If spray arm does spin freely, remove spray arm clip, spray arm and the post assy (the thing the spray arm attaches to). Try your WikiFix again. This time add baking soda to the hole the post assy came from. Top it off with white vinegar. Leave it overnight. In the morning, stick your finger down the hole where the spray arm assy sat. You should feel a plastic thing. This is a propeller attached to the recirculation pump. You need to free it up. Get that thing moving with your pinky or a chopstick or whatever. Try the machine without the spray arm. You should get water blasting up from the hole. Reassemble the spray arm.
Nov 26, 2008 | Equator 20 in. PLS600 Free-Standing...
1996 Honda Civic Wiper Spray problems
You will not be able to tell whether the spray nozzle is clean just by looking at it.
Poke it with a fine needle and keep trying to spray. If it is blacked,it will soon clear up.
I take it you can hear the spray motor running when you depress the switch.
Nov 11, 2008 | 1996 Honda Accord
Upper sray arm does not turn
Take the bottom spray arm off and take out the screen etc. When these are removed it will expose the volute cover. The volute cover is what the lower spray arm attaches to, there will be a few screws that hold it on, when the screws are removed it will lift off. Under it you will find a check ball, it should move freely, it is most likely stuck in place, if it is free it and clean it and the track it rolls in. re-assemble and it should work. hope this helps
Aug 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Top rack dishes have grainy particles on them after washing and will not come clean.
Run the dishwasher and observe the spray arm,if split it will spray water down: Also check water in tub, is it filling up sufficiently to get near the heater? If it has a upper spray arm does it spray water? If not you may have a clogged upper spray arm.
May 23, 2007 | GE 24 in. Profile PDW7800 Built-in...
Danby 22 in. DDW396 Free-standing Dishwasher Logo
208 people viewed this question
Top Danby Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Jose Pino
Carmen Mikulic
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
