Dead motherboard My presario F500EA went dead after my niece left it operating on the bed for a day. I suspect it overheated due to blocked vents. External power supply is ok. HDD is ok. I suspect motherboard is shorted. Please help me troubleshoot the motherboard. I know how to use multimeters but I dont know where to start. I dont have a schematic diagram of my motherboard. please give me tips on how to tackle this problem. Thanks so much.
  • Mike Peluso
    Mike Peluso May 11, 2010
    I did search, many hours & could not find any type of schematic's or diagram posted on the web for the F500EA board. Only a couple places to send for repair.
  • Mike Peluso
    Unable to find any schematics or diagrams for this notebook.
  • 81 Answers
Bad news - an overheated F500 is a really expensive paperweight. All you can really do is try and source a new motherboard and hope the CPU and RAM didn't go the way the board did...
Posted on Jul 21, 2009
My compaq 610 wont start up. went i connect de charger the powerbutton lights goes on en off.
When the power button blinks do you hear the laptop fans run on full speed? If that happens its because your laptop is overheating and is trying to cool down. It will not turn on until it cools down to protect from damage due to heat.
Use your laptop on a hard surface and dont block its vents with anything. If you want to use it on bed keep it on a laptop cooler or a thick book to allow ventilation.
If laptop doesnt turn on at all, the motherboard might be damaged. Take it to repair shop and check whats wrong.
Nov 01, 2013 | Compaq Evo N610C Notebook
Battery keeps going flat
Check alternator voltage output, might be low. obd2 scanner
Jun 12, 2013 | Cars & Trucks
Oven on convection for 45 minutes sort of thud then went dead no lights nothing, fuse is ok came back to it 3hrs later and is working again?
That is usually an overheating problem. It may be due to blocked air flow, a slow convection fan, or a failing convection thermostat / TCO.
Jan 07, 2013 | Microwave Ovens
I have a 2011 Roadking Classic, the speeding quit. When riding if I twist the throttle back it shuts down like cutting the switch on and off. And at one red light the bike went dead. It restarted but the...
Hi 2011vibr8tr, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day.Harley Diagnostic Codes 04 to Present
May 22, 2012 | 2011 Harley Davidson FLHRC Road King...
My dell studio 2558 screen is blank and the backlight is on. what is the problem?
your inverter might have went bad. thats what gives your screen the charge
Jun 04, 2011 | Computers & Internet
My Kenmore Elite electric stove top will turn on fine, but it will randomly cut off. Then none of the burners will heat up, but lights are on like all is fine. If I turn off the power for 5 minutes it...
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
An overheating magnetron can be :
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (US homes should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
I suspect a failure or the fan, clogged filter or bad magnetron.
I appreciate your thoughtful rating of my answer.
Feb 07, 2011 | Microwave Ovens
Microwave work for 2 minut and turns off and after 5min its turns back on and do same thing
An overheating magnetron can be due to:
I would suspect a failure or the fan, clogged filter or bad magnetron.
You didn't mention your brand or model number, so I'm limited to general advice.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 26, 2010 | Amana RFS12MPS Microwave Oven
My compaq presario CQ60 is overheating how do i
the overheating could happend for the following reasons:
-check that the fan is working and the vents are not blocked. do not put the laptop on the sofa or the bed. glass may also increase the temperature.
-check that the bios is up to date. maybe the fan is not working fast enough
-are you playing a lot of games or using an application(like video editing) that uses the graphics card intensively?
download this
http://www.almico.com/sfdownload.php
to check your fan speed and temperature of your laptop
Jan 25, 2010 | HP Compaq Presario CQ70-120US Laptop
Battery dead, key stuck in ignition.
I have had the same problem with my daughter's car. She inadvertnetly left the key in the on position and the battery went dead. Apparently an electrical current is neded to withdraw the key. I put a battery charger on the car for several hours and everything worked fine after that.
Sep 30, 2009 | 1997 Pontiac Grand Am
Over heating of laptop
Causes of Laptop Overheating Physical Causes of Laptop Overheating
For a properly designed laptop, the most common cause of overheating is blocked air vents. When dust blocks the fans and air vents designed to cool your laptop, overheating results. (In some cases, blocked vents and poor design are related, as some designs are excessively prone to becoming clogged with dust).
Software Causes of Laptop Overheating
In other cases, laptops overheat because the software designed to protect the laptop – specifically by controlling the operation of cooling fans – does not work properly. In some cases, this is due to problems in the computer’s BIOS, and can be cured by upgrading to the most recent BIOS. In other cases, upgrading or changing the computer’s operating system can cause this software to not function.
If, for example, you have upgraded from Windows ME to Windows XP, the system software designed to operate the fans may no longer work properly. (What’s worse, the laptop manufacturer may refuse to provide support in this instance, on the grounds that you changed the operating system and so are no longer operating the system as it was designed to operate.) In other cases, replacing Windows with Linux has led to this problem if the proper Linux utilities to control laptop cooling were not installed.
Design Causes of Laptop Overheating
In a distressing number of cases, laptop overheating results from poor design by the notebook manufacturers. Some manufacturers cram desktop CPUs into laptop configurations, and do not adequately provide for releasing the heat that these desktop CPUs create. Others simply have failed to provide ventilation and cooling systems appropriate for today’s CPU and video chips, which hold many more transistors than in the past and so generate more heat.
Several class actions have been filed against laptop manufacturers due to overheating laptops, including Toshiba and Dell. Previous class actions have led to settlements under which compensation was awarded to owners of overheating laptops who ran up repair bills trying to get the problem fixed. More class actions related to overheating laptop and notebook computers are reportedly under consideration.check here for more information http://www.fonerbooks.com/lap_fan.htm
Oct 31, 2008 | Compaq Presario Notebook
Computers & Internet Logo
358 people viewed this question
David Payne
David Payne
