Question about Panasonic DVD-LA95 Portable DVD Player
Unable to play DVD - incorrect region code or disc type?
The LA95 is a multi regional DVD player, but yet it will not play either PAL or NTSC discs. Errorr message states the disc is the wrong region.
I have reset all the initial settings, as per the manual. The player is set to ratings 8 which is unlocked for all discs.
Daughter was mesing about with the player and she has done something which now prevents it from playing any disc!
Please advise.
Thanks in advance,
Craig (Father of unhappy children when travelling!)
  • 1 more comment
  • craig_bramha Nov 13, 2008
    Hello nginter1,
    Thanks for the quick reply. Yes it is a panasonic portable dvd player, bought in the USA. This was working fine, but now it cannot play the same disc.
    I switched the unit on, (no disc) and pressed backwards and on at the same time, as per your fix. The message initialised was not displayed. Please advise.
    Cheers Craig
  • ma6jrp Apr 19, 2009
    I also have the same problem, I have tried region 1, 2, 4. Region 0 plays fine. The DVD player is region 2. Has anybody else solved this problem?
    I have done the reset correctly but still have the problem continues.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Is it the Panasonic Portable DVD player
Posted on Nov 13, 2008
  • Natalie Ginter Nov 13, 2008
    here is one thing it says
    This unit responds to the Region Management Information recorded on DVD-Video. This unit’s region number is “1”. You cannot play the disc if the region number on the DVD-Video does not correspond to the region number on the unit.
    You can play discs marked “1”, “ALL”, or with a region number including “1”.
    Here is what I would do - default it to its original state see below -
    Do the following to reset the unit to its original factory
    settings. While the unit is stopped, press and hold
    ;], [:] (backward), and [1, ON] on the main unit
    for about 3 seconds until the message “Initialized”
    disappears from the LCD, then turn the unit off.
How to make region free dvd
Usually a region 1 DVD player will not be able to be a multi region because it needs to be able to convert between pal and NTSC to play on your NTSC TV. Unless the player is a European model then it would be possible!
Oct 01, 2015 | Panasonic DVD-CP72 5 Disc DVD/CD Changer
Region codes
dvd players are suitable for all regions but the pins may vary region to region
May 13, 2008 | Sharp DV-NC200
I put in my dvd on my magnavox blue ray player and it says disc error then something like disc not recorded for thins region code * 2 * 45 *
DVDs are recorded for three world regions (for copyright reasons and to match the electronic TV system also broadly in three world regions known as PAL, SECAM & NTSC)
You're likely in the USA as you refer to the Magnavox brand.
Your region is 1 and system NTSC.
Your machine is correctly telling you it can't play the disc because it's for Region 2 system PAL.
However, there are multi region players available, for a few dollars more, which play discs of any region or system.
Sep 20, 2011 | Audio Players & Recorders
Cant play all regions dvds on a hyudai XHD 817 portable dvd player...how do i make it region free
U can't if ur DVD player are in one specific design format like for PAL regions or NTSC regions.Only DVD players that are design for regions free formats can play both PAL and NTSC regions codes DVD disc.
Aug 15, 2011 | Televison & Video
DVD player will play some DVDs and not others. I checked the regions on the discs with the player and they should play. On the back of the player it says it will play region 1 & no region discs. ...
Unless you have a second DVD player (or a PC with a DVD drive or similar) on hand, to cross-reference the discs with, you won't be able to tell if it is the discs or the Daewoo player that has the issue. It could just be a bad batch of discs, but without the second player available to confirm this, there is little you can do.
On the other hand, some of the discs may not be NTSC, they may be PAL, and unless your player supports PAL compatible playback, it won't play it. Rare, but not uncommon (some PAL DVD players won't play NTSC discs regardless of the region code), and it is not your player that is necessarily at fault here.
Mar 31, 2011 | Daewoo DV6T844B DVD Player/VCR
What format is used when the VHS is copied to the DVD ? I have copied the VHS tapes onto Verbatim DVD-R discs. They will not play on my computer. Verbatim says I need to know what format they are in...
the most common in the US is NTFS. another used in other countrys is PAL. the format is seperated into regions, and they are as follows,
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
you can use MAGICdvdRIPPER softwareon your computer, it works with NTSC, and PAL formats and vice versa.
Jan 28, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
The player says wrong region code with every dvd i have!! help please Phillips 3020K
Where did u bought this DVD player?US,Canada,and Mexico?The DVD disc. used NTSC region format.Asia,Europe,Africa,and the Middle East.The DVD disc. used PAL region format.They can't be mix or it will not play as u find out.If u move in and out to another region of the world.U must have a regions free DVD player to play either NTSC or PAL regions.
Apr 26, 2010 | Philips DVP5140 DVD Player
I bought this so i could watch my americam region 1 dvds but cant find the code in booklet can you help please
This info I picked up from a kind of hackers site & don't have the said player, so, its hearsay:
You need a region free player or to change the region code to play region 1 [ NTSC formatted USA discs.]. To get your DVD to play NTSC or PAL enter the following commands:
  1. (Press SETUP)
  2. Press "Shift"
  3. Press "Mark"
  4. Press "Stop"
  5. Enter "0,0,0"
  6. Enter "87154"
  7. Press "Shift"
  8. Enter the region or press Fast Forward (for multi region) ....................sodeep
Nov 10, 2009 | Yahoo Diamond Vision DVDC803-04 DVD Player
Help
You need a region free player or to change the region code to play region 1 for NTSC formatted USA discs.. To get your DV-1701 to play NTSC or PAL enter the following commands:
  1. (Press SETUP)
  2. Press "Shift"
  3. Press "Mark"
  4. Press "Stop"
  5. Enter "0,0,0"
  6. Enter "87154"
  7. Press "Shift"
Aug 17, 2009 | Yahoo Diamond Vision DVDC803-04 DVD Player
I have just bought a Panasonic DVD-LA95 but did not realise that it is Region 1 only. I need to change it to region 2 to be able to use it here. Can you help please.
you need to check that it supports pal output, if its a european unit (check the manual and player bottom for the ce mark) then it will play pal discs and will need reverting to the multiregion upgrade ( a disc and a few button presses about £20 online)) if its an american unit then it wont play pal discs even if you do manage to multiregion it.
Jun 25, 2009 | Panasonic DVD-LA95 Portable DVD Player
Panasonic DVD-LA95 Portable DVD Player Logo
1,153 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
