Question about Philips Magnavox 9P6034C 60" Rear Projection Television
To converge or not converge, that is the question
Hello and thanks in advance to the ****tube guru's. I have a 9P6034-C103. The television was moved upstairs and replaced by a 62" Sammy DLP. I think the set is now jealous that it has taken a back seat. After the move the set cannot be adjusted to get the right Contrast (Picture)/brightness balance. The darks are way dark and the lights are way light. I tried fiddling with the convergence, truth is the colors are aligned with the crosshairs in both convergence screens. I'd dare say that the picture seems cloudy as in the presence of a haze. At some point during one the adjustment sessions, there have been many many of those, I recall the image further left than it belongs. It's either that or the colors are all congregating on the left edge of the screen. I'm trying to keep my spirits up, although I am very frustrated. I put the set in my bedroom in order to watch tv in bed and this problem occurs. What's even more frustrating is that the extended warranty has expired and the set was fine as long as it was covered. Again any help would be greatly appreciated.
  • Orlando Bravo Nov 21, 2006
    An update...
    I have narrowed the issue down to a scattered green image. I have been able to improve the image quite a bit via the convergence setting. The problem I still have is that in light scenes (such as outdoors) there are splotches of green throughout the screnn. When in the convergence screen, if I adjust any of the colors, there is a lot of flickering everytime a buttin is pressed. The green letters in the instructions were really blurry and splotchy, now they are readable but still way out of focus. The crosses towards the ends (left & right) are very dark, almost to the point that the color separation is not visible when moving the crosses intentionally. The arrows at the center have a vert bright glow around them.
    I apologize for the poor description of my problem and lack of terminology.
    Problem Solver:
  • 4 Answers
With the remote enter 06-25-97-Menu under there you can clear up the problem. How ever moving these can be tricky as they move with one another and trying to get them straight can be frustrating. There is a template you can order however I don't see one for a 62 inch.
Screen Templates:
50" ST4161
55" ST4162
60" ST4130-60
64" ST4160
1-800-851-8885
Posted on Jul 25, 2008
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
I have a phillips magnovox 9p6031 c103 rear projection tv. At first the screen would shrink and have an orange look, when I would go through the convergence re-set it would clear up, now the tv makes a...
This problems is the cause of 2 Convergence is dead also.Know how to solders?Buy a convegence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Nov 29, 2009 | Philips 46PP9302 46" Rear Projection...
Toshiba 42" suddenly has blue arc projecting through lower half of screen. Confirmed it was the blue tube by removing the projector lens and looking at the direct image.  Is this a bad tube or something...
This is not a bad tube it is a convergence problem. Your convergence amplifiers are malfunctioning, and need to be replaced. If you have a background in electronics, you can remove the back of the TV locate the Convergence ICs (using the schematic or service manual) and the order the parts you will need which are the two convergence ICs and the biasing resistors (you will see these on the schematic). To remove them unsolder the pins, unscrew the screws holding them on the heat sink and remove them carefully, if they stick use a solvent to break down the adhesion of the heat sink paste. Once loose, take them out and then unsolder the biasing resistors and replace them with the ones you ordered along with the ICs.
To install the new ICs put heat sink paste on the back of the ICs and insert the pins into the proper holes in the circuit board. Screw the screws back in securely, and solder the connections back.
After doing this you will need to perform a convergence adjustment, using the cross hair adjustment screen (access this from your TV menu). and the you will need to do an advance adjustment using the crosshatch pattern (also accessed from your TV menu).
Once these are done use you service manual to follow the procedures on locking the adjustments into the TVs memory.
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Mar 23, 2009 | Toshiba 42H83 42" Rear Projection...
PROJECTION TV COLORS DISTORTED
You can try to enter the menu and go to advanced setting and adjust the convergence. Push audio to go to advanced convergence and do the multipoint convergence to re-align the colors. If this doesn't solve, you may need to do a hardware repair.. all projections of this type will need a convergence IC repair sometime during their lifetime.
Dec 07, 2008 | Mitsubishi WS-55511 55" Rear Projection...
I have a 2001 Phillips Magnavox 9P5034 C103 TV. The green power light comes on, but nothing else happens. I have changed the recommended chip, but that didn't work. Is there a high voltage component that...
I would have to say that the television is not worth fixing. The problem is most likely to be in the CRT, (cathode ray tube), or in the electronics that fire the tube. with the prices as they are today, you are better off replacing your TV with a used or new one.
Oct 24, 2008 | Televison & Video
Philips - Magnavox Model # 9P6034 C103 Picture problems? Please Help
1 5 oz bottle should be enough for each tube. The small picture is caused by bad opto-couplers on the large signal board. Let me know if you need more info on the couplers and where to get them
May 15, 2008 | Televison & Video
Blinking 4 times - Sony KP 51HW40
Hello scramble5,
This might be a convergence amplifier problem or a problem in the convergence coils. I would suggest that you have a qualified TV technician check this TV out. This problem is usually due to the convergence amplifiers malfunctioning, to replace then the two modules and their biasing resistors must be replaced.
I hope this helps
Thank you,
Shuttle83
Jan 27, 2008 | Sony KP-51HW40 51" Rear Projection...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
TOUCH FOCUS ERROR on Projection Toshiba TV
My 57H81 won't converge, plus I get the "touch focus error" message. I could get manual convergence of blue, but not red. Plus, during touch focus the red would not move horizontally
Nov 25, 2007 | Toshiba 57H81 57" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
122 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
