Question about Dell 924 All-in-One InkJet Printer
Paper jam, and cannot remove it
The jammed paper is so far inside that I can't get at it either from top or bottom, so I have to take the printer apart?
  • charginghawk Nov 17, 2008
    I have the same problem! A whole bunch of paper fed itself into the printer and, like you, I can't get it out. I'm looking for my screwdriver right now......
    Sergeant:
    Champion:
  • 246 Answers
You have to aprt the printer.
If you not confident to do that please call the person how do it well
Posted on Nov 13, 2008
I have a paper jam inside my mx726 and i have apple safari which seems to be blocking the paper jam videos. Can you tell me how to open printer please?
Try removing the paper tray(s) and see if you can see the jam through the bottom. If not, open the top, grab end of the paper and pull it out. Then power the printer off/on.
Feb 27, 2015 | Canon PIXMA Office Equipment & Supplies
How do I get jammed paper out of the back of it?
This is from the user guide available on the HP.com website:
This section contains the following topics:
• Clear paper jams
• Avoid paper jams
Clear paper jams
Paper jams can occur either inside the printer or in the automatic document feeder.
CAUTION: To prevent possible damage to the printhead, clear paper jams as
soon as possible.
TIP: If you notice poor print quality, clean the printhead. For more information, see
Clean the printhead.
Use these steps to clear a paper jam.
To clear a jam inside the printer
1. Remove all media from the output tray.
CAUTION: Trying to clear a paper jam from the front of the printer can
damage the print mechanism. Always access and clear paper jams through
the automatic two-sided printing accessory (duplexer).
2. Check the duplexer.
a. Push the button on either side of the duplexer, and then remove the unit.
b. Locate any jammed media inside the printer, grasp it with both hands and
then pull it towards you.
c. If the jam is not there, push the latch on top of the duplexer and lower the
cover. If media is jammed inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the printer.
3. Open the top cover and remove any debris.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and
remove the jammed media, if possible. If not, do the following:
a. Ensure the printer is turned off and disconnect the power cord.
b. Lift the printer off Tray 2.
c. Remove the jammed media from the bottom of the printer or from Tray 2.
d. Reposition the printer on top of Tray 2.
5. Open the ink cartridge access door. If there is paper remaining inside the printer,
ensure the carriage has moved to the right of the printer, free any paper scraps or
wrinkled media, and pull the media towards you through the top of the printer.
WARNING! Do not reach into the printer when it is on and the carriage is
stuck. When you open the ink cartridge access door, the carriage should
return to its position on the right side of the printer. If it does not move to the
right, turn off the printer before you remove any jam.
6. After clearing the jam, close all covers, turn on the printer (if you turned it off) and
resend the print job.
That's about as much as I can find for you. If you look in you user guide which is on a CD that came with the unit, you can go to page 152 through 154 to see diagrams that go with these instructions. Good luck!
Nov 13, 2014 | HP CM749A - Officejet Pro 8600...
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon mp600 was printing a photo when the error message "paper jammed" came up. I know the paper is in the machine, though I can't find it.What do you suggest?
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
    Note:
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jam
Also see this:
    Note:
Top
Top
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper JAm
There are three places to clear the jam: 1. Paper tray (remove it and feel inside, clear paper. 2.Open the front (above the manual feed slot) inside is the drum - remove that and the toner cartridge, if necessary. 3. On the back - open the rear chute. You should be able to remove the paper in one of those areas. See the Brother web site for complete pictures ans instructions. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_006.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=4
Aug 20, 2007 | Brother HL-2040 Laser Printer
Dell 924 All-in-One InkJet Printer Logo
21 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
