Question about Dishwashers
Heavy calcium buildup on the heating element - Dishwashers
  • 640 Answers
Get some c.l.r. (calcium,lime,rust) remover at a supermarket.Add a cup and run a cycle,this should solve your problem--repeat if necessary.
Posted on Nov 13, 2008
Our hot tub temp keeps dropping daily into the 90's temp when it is set at 104 degrees. When we turn the high speed blower on, it seems this is the only way we can get the temp back up to the
calcium will stick to heating element 1st and make it less able to heat water , eventually it will consume the entire surface and insulate the water from touching it and warming it and finally overheat it and cause burnout , high calcium (limestone) is usually a condition that occurs when filling via a well or stream , consider getting a load of pre softened water from a municipal water system , there should be a list of haulers in your area that can provide this service
Jan 08, 2015 | Pool & Spa
Have 2 Bosch tankless water heaters model 2400 ng. Won't maintain temp.
This could be a heating element going out do a ohms check on the elements
Jan 29, 2014 | Bosch Water Heaters
I have a Quiet Guard Standard model #587.151524 that is not cleaning the dishes. I took the bottom spray arm and screens out and cleaned them, (they had a heavy buildup of what I would say is calcium. The...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 22, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
High operating cost. Element has 1/2 inch hard water build-up, i.e. calcium, lime. I change the heating element every 2 months. Does the unit have a thermocoupler? can't find anything in the manual or the...
I think your problem is the buildup, which would cause your elements to work much harder trying to heat the water - especially if you have well water as opposed to chlorinated city water, although city water still has calcium, etc. in it.. Add a whole house filter to your water line where it comes into your dwelling - there are a myriad of elements available at varying microns to catch the calcium
and other contaminants. These filters normally need changed every 3 months - I would check your after a month to see what it is catching. These whole house filter systems are not expensive - check out your local hardware or plumbing store, I'm sure they can guide you to the proper set up ( after you verify what they say through some online research) . Better safe than sorry !!
p.s.there should be 2 elements in your water heater - 1 above and 1 below, so after you've installed your filter change both elements - I'm sure you'll find they last a lot longer!! Also - before you cut off water to your home for the install, fill up a clean 5 gallon bucket and RINSE the filter element , then turn off the water supply to your water heater to prevent a loss of prime and water hammer to the pipes.
Nov 10, 2010 | Reliance & 40 Gal Mobile Home Water Heater...
Calcium bildup
I created a tip sheet to help with this, let me know if you have questions beyond what is in this link.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
May 05, 2010 | Frigidaire Dishwashers
Calcium/Lime Build-up on Dishwasher Heating Element
You can clean the calcium/lime build up with CLR and a scotch brite pad.
Apr 27, 2010 | Frigidaire Dishwashers
Calcium buildup on heating element. It's unmovable.
The reason for the calcium build up is normally a hard water,Make sure the salt dispenser is full (located at the bottom of the machine under the lower rack,before you add salt get a descaller from you local hardware store, most carry for dishwashers.Follow instructions, this may require a few treatments before it is gone,when it is right then check salt level etc.Hope you come right.
Dec 30, 2009 | Dishwashers
Lime buildup
Limescale is mostly calcium or magnesium carbonate and will dissolve in acid. If you don't want to use the commercial limescale removers you could try soaking the element in vinegar, or lemon juice, or coca-cola and then rubbing at the residue with a plastics pan scourer. (Wrap the element in some cloth and keep basting the cloth with your chosen remedy for a few hours before trying the scourer.) If you can reduce the dishwasher temperature below 55C this will help a lot in the future.Hope this helps a bit!
I'm sure you know how this site works - everyone wants to be a guru and only Fixya! ratings are worth having. If my offering doesn't work for you, just forget the rating :-)
Thanks in advance D.
Dec 02, 2008 | Frigidaire 24 in. GLD2350RC Energy...
Dishwashers Logo
226 people viewed this question
Top Dishwashers Experts
