Question about LG 24 in. LDS 5811 Built-in Dishwasher
Smell in LG LDF8812ST
My dishwasher has smelled almost since new. I noticed it does not have a venting system to the air, and it dries the dishes by the condensation method per LG. I called them many times, had 3 different repairmen and 2 plumbers out, changed drain hoses, direction of hoses etc... result is that it still smells really bad. My family will not open it, we leave the dishes in the sink and then all at one time they get put in for minimal open door time! Someone please help me with this 1200.00 dollar mess! I have this very same problem as mentioned above. I can't stand to open it. I bought it new in 03/2008 and have had the problem since the first time we ran it. What can be done to fix it?
  • Anonymous Nov 13, 2008
    We have the same problem with our LG dishwasher purchased in 3/08. Nothing we have tried has solved the problem. Not happy about this!
  • 833 Answers
First, scrape your dishes clear of food before putting them in.  Rotten food makes smells.  Second, use a good brand of detergent in the recommended amount and use the heating cycle to heat the water up.
Most dish washers have a dryer heat cycle but this one apparently does not.  This may cause mold in the machine.
How to get rid of the smell:  With no dishes in the machine, add half a cup of bleach in the bottom of the unit and do a full wash cycle.  If the unit still has an odor, get some baking soda...about a half cup and put that in the bottom of the machine.  Close the door and leave overnight.  Then, run the machine through one wet cycle...say a wash cycle and then it should stop smelling.
Hint:  When leaving dishes in the machine between uses, leave the door ajar...do not close tightly.
Posted on Nov 16, 2008
Rotten smell coming from dishwasher
run some bleach though it when its empty, run a full cycle,
Aug 12, 2014 | LG Dishwashers
ICON DISHWASHER
Check and make sure the Air Dry button is not engaged. Check the clean out at the bottom. When you push the top rack in insure it is hitting the opening in the back. Finally purchase some Lemi Shine Machine cleaner for the smell, it's likely you have a some stuff lurking in the screens causing the smell, this made my Icon dishwasher work like new.
Apr 07, 2014 | Electrolux Frigidaire Professional Series...
I have a strange situation going on in my house. When I turn on my airco frequently I get a nasty smell from the airco vents. Sometimes we have it running all day and it's fine (no smell at all) then at...
You should look in the air handler( Where the indoor blower is located) or in the plenum (where the duct system originate at the air handler) for any dead and rotting rats. Residential central air systems are sealed (uses circulated air only) and do not use outdoor air.
Aug 27, 2013 | Heating & Cooling
Would the stainless steel make the inside of the dishwasher smell awful when half full of dirty dishes after only 2 days? I noticed under the screen on bottom of tub that not all the water completely...
stainless steel will not smell or rust that why its used,the cause of the smell is twofold 1 dirty dishes should not be left unwashed in the machine to long a bectearia starts to grow within a couple of hours and starts the smell process,2the filter system at the bottom of the machine should be checked everyday [heavy user]light use every [2/3 days],the screen at the bottom of the machine is the filters,some models do leave some water in the bottom.adrian,,,,,
Aug 12, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher and everything run in it smells like mothballs
there will be some loose conections,the heating coil might be defective and please check if there is any wire damage undrneath the machine.if yes rectify it then provide a rat mesh.
Jun 23, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
No heat, not drying
This sounds like you have a problem with the thermostat.
Repair would be cheap. Are you mechanically inclined?
Nov 25, 2008 | LG LDF8812 Stainless Steel Built-in...
Jennair dishwasher jdb8910aww
Start by puting timer in heat dry for about 4 seconds and see if element got warm. If so check you rinse aid and make sure it is full. I like the turbo dry made by jet dry. If it is empty, this is your problem. about the smell, you would use a cleaner such as diswasher magic made by GE. If element did not get warm, put unit on heat dry and and test voltage at the element. 120 volts present replace element. if not check voltage at thermal fuse for 120 volts. If no voltage there replace timer.
Jul 26, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Well, I can't tell you how to fix it exactly, but we had the same problem when we moved in to this house. The dishwasher *always* smelled like rotten meat, it was awful. We discovered, when the garbeurator backed up one day, that the garbeurater pipe somehow attached to the dishwasher, because it all came pouring out through the dishwasher a few minutes later. Truly disgusting, it explained the smell, and now we don't use either of them!
so my suggestion is make sure the garburater isn't somehow hooked to your dw.
Jul 04, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
518 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
