Puchased A Yamaha DSP-A1092 Amp from Auction turns off
The Amplifier keeps turnnig off intermitently, you need to turn it back on at the amp only, could this be Caps in the power supply?
    Novelist:
    Champion:
  • 218 Answers
I doubt it. Sounds like it is going into protection due to bad output transistors or some such. Time for a trip to the repair shop it sounds like.
Posted on Nov 14, 2008
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
May 15, 2012 | Yamaha DSP-A1000 5-Channel Amplifier
Keeps tripping out
Had a very similar problem on a DSP-A1092, found to be the temperature sensor on the heatsink open circuit. I fitted a variable resistor to mine and adjusted it to just below the specified resistance of the temp sensor (I had the service manual at the time). Permanently cured the fault. As the amp never ran hot,it was not a problem if well ventilated. Of course it could also be shorted speaker wires at any of the outputs too.
Dec 29, 2010 | Yamaha DSP-A3090 7-Channel Amplifier
With the Yamaha A3090, we have it hooked up to our TV with is Satilite and have speakers hooked up but, when watching TV the Auto Detect feature keeps coming on and it is going back and forth from VCR2...
This can be a system malfunction, make sure that there was no stuck buttons on both tv and remote, try to remove and replace the remote battery.
Hope this helps
Oct 07, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Yamaha Amp DSP A-3090 Power/function/Remote
These issues can only be fixed by an audio-tech.
Do a websearch around your area for a repair person
Sep 30, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Where i could find the schematic diagram of yamaha amps model DSP-A1000
A common problem on these amps ie no sound is due to dirty switches and tone contols,amp face needs taking off and contact cleaner needs spraying into all controls...
Jan 14, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Dsp-a1000 dead
output stage problem, systems trips due to protection. have the power amp transistors checked. the rotating of function switch is normal, its like a routine system check
Jun 22, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Flashing volume control
THE MUTING CIRCUIT IS ON AND IT CANNOT BE DEACTIVATED BY UNPLUGGING UNIT...YOU MUST HAVE THE REMOTE TO DEACTIVATE.
Sep 10, 2006 | Yamaha DSP-A1000 5-Channel Amplifier
433 people viewed this question
 Grubhead
Grubhead
