Question about RCA CDRW120 2-Disc CD Recorder
Cd recorder/player will not power up.
I have a RCA CD Recorder and Player. It really has worked well over the last few years, but today I tried to turn it on and I see nothing to indicate that it is turned on: no lights, no disk drawers come out, etc. I tried it in a different plug and it does not work. I tried moving the fixed plug and cord around and there does not seem to be a short. The only thing I noticed was a strange, faint plastic smell in the cabinet. What can this be and what might it cost to fix it? Is it worth it after 4 years?
    Problem Solver:
  • 20 Answers
Hi, I'm assuming you have changed the fuse inside the plug. The poblem could be an internal fuse inside the amplifier which has blown due to a possible power cut or surge. The burning plastic smell could also be a few capacitors that have blown.
It sounds like a definite open up and take a look around job, if you want to you can open up the cd player and take a look for yourself, but BE CAREFUL. A service engineer may require to change the power board inside the cd player or other boards, it is very rare for an engineer to change components unless it is easy to do so. I believe some engineers will have a look around for you at no cost to you and evaluate the problem. As for cost your probably looking at over £100 for parts and labour depending on the engineer.
Hope this helps
Rob
Posted on Nov 13, 2008
May be duplicate... I have 2 Denon cdr-w1500 recorders. They both started the same problem at the same time. I just cleaned them with q-tips and canned air (no q-tip fibers were left inside the units). ...
continuest uses of ant cd player or recorder will damage the eye. try 2 leave it upside down 4 a day 2 see if there is any dry spots in the eye. if not restart the cd player all day until it reboots
with a cd any kind. if unit is broken time for a dvd ,cd recorder/player. good luck buddy
Aug 24, 2014 | Denon CDR-W1500 2-Disc CD Recorder
Convert cassets to cds on classic recorder model cdr200
Connect the Play or out from the cassette and connect to the rec or in on the CD recorder using some descent RCA cables. Good luck!
Jan 13, 2013 | Classic Electronics CDR201 CD Recorder
I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling arrangement through the amplifier. I have not been able...
Your new cd player/recorder is a "component piece" as is your turntable,cassette player, reel to reel or CD player. Connect it as you would any other component piece of stereo equipment. Set up your recorder to "record" in real time(not high speed or synch record). Your tape recorder records anything that is playing through your reciever to your speakers. So, treat your "CD" recorder as you would a "CASSETTE TAPE" recorder. Play your vinyl record on your turntable and record to CD on your CD recorder ! Pay special attention to the dubbing speed, you will not use "synch or high speed !! Good Luck
Feb 26, 2011 | Audio Players & Recorders
Not able to record cd get message unreadable cd
I found out that memorex cds that have on the package (for use in audio recorders)work every time.They're red label packaging,I hated buying cds only to find out they dont work. Dont forget READ THE LABEL look for (use in audio recorders)
Dec 24, 2009 | RCA CDRW120 2-Disc CD Recorder
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
RCA Digital Voice Recorder RP5120
I have just purchased RCA DVR RP5120. HOW can I download to my Itunes on my Mac?
Jun 10, 2008 | RCA RP5010 Digital Voice Recorder
RCA CD recorder/player CDRW120
You sure it's recognizing the CDR? And you are using 'consumer audio' cdr? Watch it at all times. If it 'opc fails' after you put a blank in it still shows as a CDR and 0:00 on the display but won't record. It's easy to miss.
Nov 02, 2007 | RCA CDRW120 2-Disc CD Recorder
Recorded finalized CD's will not play on standard CD player
Are you using the same brand of discs you used to? Do they palyback on the machine in both the record and the playback deck? Do your old cdr's you recorded still play in the standard cd player? You can try the diagnostics - hold down the 'play' and 'fwd' keys on the record side as you power it on.
Oct 31, 2007 | Philips CDR778 2-Disc CD Recorder
Durabrand 3-Piece CD Boom Box w/ Radio Cassette Recorder,
Does it happen when playing cassette or radio? might have a problem with the speaker wires.
Oct 23, 2007 | Durabrand CD Player with Cassette...
Lg rh177
Could be the dvd player/lens. The player sucks up dust through the
player's caddy and after a while it won't read discs anymore.
A cd cleaner or a good (gently dosed) blow with compressed air might help.
Oct 17, 2007 | LG RH177 DVD Recorder/HDD Recorder
RCA CDRW120 2-Disc CD Recorder Logo
63 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
