Question about RCA F25254GY 25" TV
Why did my TV shut off and is squeeling?
It shut itself off and is squeeling until I unplug it from the wall. Then when I plug it back in it wont let me turn it back on and it still makes the high pitched ringing noise...or squeel...whats wrong with it and how can I fix it?
its and RCA model F25254GY and was made in 1999
  • Anonymous Dec 22, 2008
    had pwer sending unit replaced cost $40 dollars lasted another 4 years
I have the same model RCA tv, It woked great for several years then it started shutting off or flicking the menu off and on, I looked at the back of the set and there was a lot of dust so I took it out side and removed the cover and the inside was loaded with dust so I blasted the dust out with compressed air carefully, I then sprayed the circuit panels with CRL circuit board cleaner. There was also a dead moth stuck on one of the circuit panels, got rid of it and the set has worked great ever since.
Posted on Jan 16, 2009
    Sergeant:
    Champion:
  • 346 Answers
Check fiyback
Posted on Nov 13, 2008
SOURCE:
Sudden rainbow vertical lines, Loud squeel. wont turn off. Whats wrong?!
good first shut off the outlet for what is looking like this with your tv connection problems with the drain tube of images giving us the inside source for capacitors in a technical lead for the electronic exchange of capacitors and diodes for your device
Sep 06, 2012 | Samsung LN46A500 46 in. TV
-Plugged into wall -Red LED on -Remote and side POWER ON/OFF will not turn TV on. -unplugged and waited over night then plugged in and it worked fine until later that day. TV turned itself off. Now...
Did you ever got the solution for this problem?
I have the same, I did notice that when I lift my tv from the bottom, attached to the wall support the tv turn on by itself, weird no?
Jun 22, 2011 | Samsung LN52B530 LCD TV
Tv shut off, and wont turn on. It flashes when you press the power button. NO clue at what is wrong.
is the tv on a power strip? unplug the tv from the power strip or wall outlet wait one minute then plug back into the wall outlet and not a power strip. TV should power back on.
Oct 12, 2009 | Sabre LCT371BKA LCD TV
TV shuts off on its own and wont come back on until unpluged.
On the Deflection board CK 3 capacitors cp150,cp114,cp120 If cp150 is puffed up on top it is bad 2200uf 16v /other 2 caps are 220uf 35v.Also resolder all pinns on FBT
Jan 13, 2009 | RCA D52W23 52" HDTV CRT TV
Panasonic pt-53wX42, power wont stay on. Turn on, no picture then it will turn off by itself after 5 seconds. The red power button will flash on and off until I unplug unit and start the whole process...
I'm no expert, but I'd start by taking a "VERY GOOD LOOK" w/magnifing glass if possible , @ UR Wall Outlet Power Cord. Change to different wall outlet. Ur Power Cord "should" just pull right out of the back of your TV. If nothing in those places, then take off back panel (or part where power cord plugs into TV & AGAIN inspect area around where power cord attached for, yeah, that's right, the dreaded black area around plug-in area. Maybe it's just a bent prong. Any other funny things going on that U didn't mention here? Good Luck Leonard aka quikstudy@cox.net
Jul 23, 2008 | Televison & Video
TV turns itself off after a few seconds, no picture at all
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
Samsung DLP TV Powers Off by Itself
yes i have the same problem i need help
Aug 31, 2007 | Proton MM2701VT 27" TV
RCA F25254GY 25" TV Logo
122 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
