Question about Homelite Garden
Homelite runs wide open all the time
my homelite 330 chainsaw runs full throttle all the time, what is wrong?
Intake boot under carb is probably bad, mine did the same thing and this was the problem. about a 6 or 7 dollar fix
Posted on Apr 11, 2009
  • Sid Browning Sep 09, 2013
    Where to I get the rubber boot to replace this problem.. OEM parts are obsolete.??
  • 211 Answers
Hi shoefam
check the cable to the trottle of the carb and the gasket.Disassembly the carb and check it.
savumihai71
Posted on Dec 01, 2008
Why does homelite chainsaw runs wide open?
if your saying your saw runs full speed as soon as it starts , one of two things is happening :
(1) your low speed carb jet is too far open
(2) your throttle trigger has disconnected or become stuck from your carburetor and now the throttle blade inside carb is full open
Jun 15, 2014 | Homelite Garden
Homelite 23 av will not run wide open
generally when you have a problem at wide open throttle it is a sign of the unit not getting enough fuel. It can be either a simple carburetor adjustment on the high speed side or a kit in the carburetor to replace a stiff or stiffening diaphragm
Jan 14, 2013 | Homelite Garden
I have a Homelite 330 chainsaw that I bought in 1990. It barely gets used and I have never done any maintenance to it. The problem is when I start the saw it runs wide open for a few seconds and then...
I will share with you the most common problem experienced with the model 330 with that type of symptom. Due to the anti-vibe system design of this saw, the carburetor is connected to the cylinder by a rubber "boot". Should this boot become damaged it creates an air leak and will cause the saw to overspeed and generally not run well at all. While there are other causes of this symptom, too many to list here, this is the most common with that model. Hope this gets you in the right direction.
Feb 22, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
Hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 09, 2010 | Homelite ZR10926 16" Chain Saw
Homelite timberman only runs wide open
im no pro but id start with the throttle stop adjustment and the low speed jet.
screw low jet in, till its fully seated, do not force it. then back it out 1 and 1 / 8 turns. this should get it running and ideling.
Feb 28, 2010 | Garden
Not running at full throttle
close to the carb you will find two tiny screws. They are labeled H and L. L sets the idle speed. H sets the max RPM. Hold the throttle wide open and turn the H screw. When you find the very top end, back it down some or it will be running too lean. That would make it run hot, and provides less lubrication. Could result in engine failure if you run it too lean.
Dec 23, 2009 | Garden
Homelite saw runs wide open(homelite ut10520)
There is a recall on the UT models, all you have to do is call the costumer service center for homelite. they will give you a number for the closest warrenty center that will adjust you throttle cable free of charge. I went through two UT 10520's before i started researching the problem.
Feb 02, 2009 | Garden
Garden Logo
709 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
