Question about Casio Exilim EX-S500 Digital Camera
Battery will not hold a charge
Two months ago I was shooting on a short crocodile boat tour in Florida, well the guide thought it would be great to do a 180 in the middle of Everglades swamp as I was lining up a sweet shot!! Funny Guy!! Result being, I nearly slid out of the boat to become aligator food and the camera was nearly drenched. It got pretty wet, but was NOT submerged or soaked. I assumed that a high tech little piece of quality innovation could take this, provided I dried it our thoroughly, which I did. Ever since I have not been able to take more than 6 pics without the battery going flat. Steps I have taken to overcoem this 1. DAYS on the charger. Literally, I realized the only way to get ANY pics was to charge it constantly, so its always on the charger now. 2. I bought a new battery. No change, still goes flat after 10 or so shots, or being off the charger for more than an hour. PLease help!!
  • 374 Answers
Camera + water is like wicked witch in Wizard of Oz. You are going to have to send your camera in and see if they can save it.
Posted on Jul 08, 2007
SOURCE:
I have a '94 Mercedes S420 with onlly 84000 org. miles It is showroom in appearance and mechanically has been serviced and parts replaced as regularly. My M B.. service center has not been able to...
starting up is way to slow
fuel pump pressure down
or EFI system fault , a faulty starter
if that all checks out
the 4 day to flat battery
parasitic draw from alternator ,
starter solenoid or starter motor
or ignition switch
you can buy quick release type battery terminals like used on marine boats
charge the battery up
and disconnect the battery terminals
until you want to drive the car again
when back home undo the battery terminal
Mar 20, 2017 | Mercedes-Benz S-Class Cars & Trucks
New battery just put boat in water always had a solar powered charger on battery took it off about a week ago today went to start boat battery dead. I do not know if it has altanator or what have a friend...
You will need to do 3 tests:
1 - you must find out if you have a short in the wiring: disconnect the + cable from the battery and put an ampermeter in there to close the circuit; if a current is detected it means that you have a short and it will drain the battery. To locate the short start disconnecting wires and look at the meter - when you will disconnect the wire that goes to the failed wire or part the current will stop flowing; find the faulty part and fix or replace it.
2 - you must find out if the alternator is charging the battery correctly: start the motor, wait for half an hour then measure the voltage on the battery. If it's below 14.1 volts then the alternator is failing and it will have to be replaced.
3 - you must find out if the battery is in good working order: after the second test has finished shut down the engine and disconnect the battery; wait one hour and measure it -if the voltage on it has dropped to below 11.8 volts then the battery has aged and it's no longer holding the charge so replace it.
Jun 06, 2011 | Sport & Outdoor - Others
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
2002 Chrysler Town & Country - Driver Front Dash Speaker Buzzes
The first thing I would do is pull the stereo out of the dash and unplug it . If the buzzing stops the stereo is bad get a new stereo. Its not hard to remove the stereo. Right above the cup holder there is a small cover you need a very small screwdriver to remove it . Under that is a few screws take those out then grab the plastic cover that runs around the stereo and pull towards the back window it simply pops off (No screws) After you remove that cover you will see 4 phillips head screws that hold the stereo in remove them. Last slide out the stereo there will be 1 plug with alot of wires that is the power and speakers . Unplug it . The other round plug is the FM antenna
Mar 26, 2009 | 2002 Chrysler Town & Country
1993 Goldwing Aspencade With Slight Engine Miss??
could be a out sinked carb or gum from sitting gas won't last long
Feb 27, 2009 | 1993 Honda GL 1500 Aspencade Gold Wing
Can't get the power on...
I would try a new battery. How old is the battery? Your probably right about the battery not holding a charge.
Feb 17, 2009 | Samsung Cameras
Ive got a Razr phone and it's not charging??
the battery is no good, the battery charges but it can't hold the charge. This could be because of age or damage.
Apr 15, 2008 | Motorola Mobility RAZR V3
Casio Exilim EX-S500 Digital Camera Logo
46 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
