Question about HP PSC 1350 All-In-One Thermal Printer
P rint Cartridge gets stalled
I had this problem before and someone on line walked me through a reset procedure that involved un plugging it and holding down two of the buttons when I started it back up and I just need that procedure again.
    Scholar:
  • 121 Answers
To reset the printer
  1. Disconnect, and then reconnect the power cord
  2. When the lights begin to flash, simultaneously press and hold the On/Resume button and the Number of Copies button.
  3. When only the On/Resume light is flashing, release both buttons.
The reset is complete when the On/Resume light is steady.
Please don't forget to vote!
Cheers
Posted on Nov 13, 2008
Error message "Speed Stall" stops will not run. :(
You must try a) LUBE very well the Deck belt and walking belt b) Recalibrate the machine.
If after this situation persist.
You must replace the EPROM(software is coming inside, and can be corrupt), call to the company.
for to get it.
Blessing.
How To Lubricate Treadmill
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 06, 2017 | Tunturi Exercise & Fitness
Wont Print no icon on the control panel or device and printer page down load to print test page Les
Browse below link, select OS, download full feature drivers.. save it..Installation procedure: Un plug USB cable, un install loaded drivers through control panel. Restart the system run the drivers, connect the USB cable when its appears on screen run rest of the drivers.. once installed check for icon in printer drivers.. print test page & confirm for the print as well as check for the scan...Link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3418707&lc=en&cc=us&dlc=en&lang=en&cc=us
Dec 30, 2011 | HP Photosmart C4580 All-in-One InkJet...
I need to replace the power steering rack
Labor guide calls for 5 hours. That's for someone who has done it at least 10 times, has a good selection of tools, and a hoist. Much more time consuming on your back, but it can be done. Quite messy though. You will still need an alignment after though. If you're very confident you can handle it, have a good jack, and very sturdy tall jack stands, good tools(including line wrenches) get back to me and I'll walk you through it. Better though to get a manual. Just remember, it sounds easy in the directions. However every part of this job involves rusty fasteners under the vehicle. It also involves lowering the engine cradle. Not for beginners. Not judging, just sayin'. Good luck.
Oct 27, 2011 | 1999 Ford Taurus
My Proform 695 LT runs fine when Iam not on it but when I get on the machine it starts pausing in between running or even a slow walk
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
May 29, 2010 | Proform 695 LT Treadmill
Reebok treadmill
Hi James
May 24, 2010 | Reebok 8050 ES Treadmill
The treadmill is loose. How can this be fixed?
If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud, then find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability.
If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt Tighten the bolt and test. If the problem is not corrected, repeat steps above and retest.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. Follow this procedure:
First remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Rear Roller Adjustment Bolts
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley and front roller must be replaced.
Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud. Loosen the rear roller and remove the two adjustment bolts. Some models have a spring loaded tensioner on the right hand side so be careful when removing these bolts. After the bolts have been removed, remove the rear roller end cap(s). The rear roller should now simply slide out of the walking belt.
Remove the motor hood. Using a black permanent marker, make a mark on the front roller adjustment bolt on the motor compartment side at exactly where it fits flush with the roller so you will know where to retighten it later. The adjustment bolt is on the right hand side of the front roller. Then remove the bolt with a 7/16” wrench. then remove front roller and replace with new reverse procedure mentioned above
May 16, 2010 | Proform Sport 1000 Folding Treadmill...
Error 1200 what is this. I cannot locate my user's guide
Hello Sir, The error on this printer means that the AIO which is All-In-One is stalling or completely stalled. The repair procedure is given below. But you can reply me back clarifying that is it showing Cartridge error 1200 or Hardware error 1200. :--------- THE PROCEDURE:--------------------------
  • Turn the Printer completely off to turn off AIO.
  • Then check for any Paper inside.
  • After confirming that there is none then Un-plug the AIO from the Outlet located in the wall.
  • After 10 Min, replug and check function.
Also the problem can be on the Catridge ( Most Commonly ). In this case you need to check the Catridge socket for any obstruction and also check that the Cartridges are not stuck or misplaced.
Reply me for any further assistance on the Issue.
If the printer is only showing that error 1200 then take care of both the AIO and cartridges reset. Both have to be done.
Thank you Sir, Have a nice day.
Oct 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
LEXMARK X63 NOT RECONIZING LEFT CART.
I did find a procedure online to clear the memory and that did the
trick. Here it is, may help someone in the future:
Open lid, take both cartridges out. Physically remove the power cord from outlet or back of unit. While pressing the Stop/Clear button, plug cord back and kee pressing until a message saying "clearing memory" comes on. Reinstall ink. You're done, the message should go away.
May 03, 2009 | Lexmark X63 InkJet Printer
No internet signal from router in other ports
Hello, Under the wireless menu on router you must give a ssid name and enable and save to turn on wireless , hoe this helps?
Mar 21, 2009 | Linksys Wireless-G WRT54G Router
Epson Stylus T10: Horizontal bands when printing cyan
With I could post a solutions but I have the same problem! Cyan has horizontal gaps, rest of the colors seem to be ok. I've realigned and cleaned the heads many times.
Mar 17, 2009 | Office Equipment & Supplies
HP PSC 1350 All-In-One Thermal Printer Logo
123 people viewed this question
Ben Johnson
