Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dishwasher fills and drains at the same time
After dishwasher starts fill cycle, it starts draining. It fills again with very little water to wash. Top dishes are not getting clean and dishwasher soap leaves a residual on bottom utensils.
  • Anonymous Mar 25, 2014
    UNIT STARTS FILLS WITH WATER WASHES BUT KEEPS RECYCLING ON WASH CYCLE. COULD CONTROL MODULE NEED TO BE REPLACED?
  • Anonymous Mar 28, 2014
    top drawer leaks when draining. Does not appear to lead during the filling or running. Water appears to come from some of the holes ont he bottom of the drawer. cleaned out the drain, I see nothing obvious but am not sure where to go from here.
  • 126 Answers
Your water is syphoning out make sure your drin hose is up
Posted on Dec 13, 2007
SOURCE:
Why is my countertop dishwasher stuck in drain mode(s), and won't initiate or complete any wash cycle?
normally if a dishwasher fills then pauses it is trying to read the water level if it fills again it is trying get a reading from the pressure switch when it cant determine the water level it will drain to prevent it leaking, however you should get a error code for this kind of fault which makes me think it is the control board which is at fault by not being able to read the sensor rather than the sensor itself not working
Oct 08, 2014 | Dishwashers
Moyer Diebel 301 always draining
what I can tell you is that if the water temp is not high enough say 120 deg, the dishwasher washing cycle will extend.chk your drain hose and float valve for fill drain issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/phillip_77d32603f8052503
Feb 12, 2014 | Moyer Diebel 24 in. 301HT-40 Built-in...
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
I have a problem where my dishwasher starts its cycle, filling with water, then as it starts it immediately drains as the spray arms are moving. Since the water is draining the dishwasher then pauses to...
It sounds like your motor is stuck in the reverse position. It could also be in your timer. I would suggest calling a qualified technician for the one. Just because the parts are pricey and depending on how much a new dishwasher cost. Atleast get a diagnosis so you can know if its worth fixing or buying a new one. If you have anymore questions please feel free to comment me back.
Jun 05, 2011 | Danby DDW496W Free-Standing Dishwasher
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
WATER ONLY FILLS 1ST TIME ON ANY CYCLE
Hi, After the first cycle, and after it drains/spins, does it start agitating when the next load of water is suppose to be filling?
Please let me know so I can assist you further. Sounds like the pressure hoe from the tub to the water level switch is plugged.
Thanks
Vic
May 17, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
437 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
