Question about Samsung LN-T4671F 46 in. LCD Television
Channel number display won't turn off
I have a Samsung 550 LCD TV. When I watch TV through my cable box, there is a number 2 permanently in the top corner of the screen. It goes off when I turn off the cable box. This only started happening recently. Any way to turn it off? I'm pretty sure it's not associated with the cable channels.
  • 1 more comment
  • wildexpressi Nov 29, 2008
    I have a Sharp LCD LC-46SB54U, I have th sane problem. The number 2 is displayed in the upper right corner.We cannot figure out how to turn this option off.
  • Anonymous Dec 21, 2008
    i have same problem. i want an answer!
  • Brad Morgan
    Brad Morgan Dec 23, 2008
    I am in the same boat. Please Help!
    Problem Solver:
  • 5 Answers
This is a common problem with some cable boxes. Most likely it is not the television. Try to unplug the cable box for about five minutes to allow it to reset. When the cable box reboots it should reset itself. Plug the cable box back in and see if the number is still stuck on the television.
Posted on Dec 23, 2008
Samsung lcd tv loud pop
It sounds that the main filter capacitor has bursted out due to over line voltage. Check and replace the main power regulator board. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
Apr 25, 2013 | LG 42LC2D 42 in. LCD HDTV
Insignia TV won't pick up 1080p from Blu Ray
hi there, you did not mention what you are actually watching on the bluray player, i.e is it 720p or 1080p ?. Also, how do you know it is actually 1080p from your cable box ?. And what is the model number of your TV ?.
Oct 12, 2017 | Insignia 42" LCD Flat-Panel HDTV
What channel is the tv needed to be on to get cable, i push the wrong button on my tv then now is unable to get back to the cable channels.
Most cable TV systems that use a set top box or converter output on channel 3 or channel 4.
If you have HD cable service however, you probably watch on one of the A/V or HDMI inputs (Video 1, Video 2, etc.). Simply press the Video or A/V input selector, slowly & repeatedly until a picture & sound is seen and heard.
Apr 01, 2011 | Proscan 42LA30H 42 in. LCD Television
I can't get all the channels on my set top box.
Thanks for working with me to solve your problem. The reason you cannot watch those channels on this TV is because you are using an incorrect connection between the set-top box and the TV. A co-axial cable cannot carry an HD signal.
You will need to connect your set-top box to your TV with one of the following cable types.
1. HDMI
2. Component A/V
3. S-Video with separate audio cables.
You will need to check which sockets you have available on both the set-top box and the TV to determine which cable you should use.
Following this, you may also need to run the channel scan again. They should already be tuned, but currently you are not able to watch them. The correct channel numbers for these stations will depend on your region.
If you have any questions or need any further assistance, please let me know.
Regards,
BElectric
Jan 05, 2011 | Televison & Video
Constant channel display
Press Info " i " or may be Display button on Tv remote, on-screen display will disappear.
Jan 03, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Channel displaying on Samsung 32"LCD TV
Most remote controls have a "display" button. Pressing that is what gets that channel number on the screen. Try pressing it again and the display should turn off. On some brands the display may cycle through various combinations (channel number only, channell and time, etc.) before it goes away, so it may take more than one press of the button.
Dec 03, 2008 | Samsung 32 in. LCD Monitor TV
Magnavox 15" LCD TV
If the LCD only has coax, it will never display a HD picture quality. However, the Comcast HD Box will still display a picture using the coax connection. So, you could watch any HD channel, but the picture quality will not be high definition.
Jan 22, 2008 | Philips Magnavox 27MS343S 27" TV
Tv will not program in digital signals; only anolog from direct tv box
Any TV hooked up to a cable or satellite box can only "see" one channel...the set-top box (STB) converts the channel you are watching to (usually) Ch. 3 or 4. With cable you can split the input if your TV has 2 RF inputs, with a dish that won't work.
That's why the TV stays on Ch 3 and the STB changes to whatever you want to watch.
Dec 20, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
Samsung LN-T4671F 46 in. LCD Television Logo
88 people viewed this question
Henry  Thomas
Henry Thomas
