Question about Akai PT4298HD Rear Projection Television
Tv turns off on its own
When i am watching tv its turns off at least every 10 to 15 minutes
  • 20 Answers
Do not panic! Do not throw your TV away like I wanted to! Here is what may be the solution for most of the members who have posted their complaints here recently. I am not an expert, but I followed all blogs from various websites and forums, and the conclusion was the same;replace the convergence board for this model. I purchased it from www.partstore.com and since this Akai is the same model as the Samsung Model # HCN4226WX/XAA, buy the Samsung BP95-00142E Convergence board for $77. It came to about $85 after shipping. The Convergence board has two black STK ICs and two colors of wires, a gray kind and a blue kind, all which have 'pins' and can easily be unplugged from the circuit board in the TV. It is basically a complete system that takes less than 30 minutes to install. It is a simple swap procedure,with no soldering. You only need the new board and a screwdriver! Remove the lower back board of your TV where the cables are plugged in (do not unscrew all the screws for the screen, as it is unnecessary, and might just damage your screen if you are not careful.) It has a u-like shape and comes off easy. Detach the gray wires connecting your old board to the rest of the circuitry, and detach the blue wires connecting the old board to the circuitry. On the old board, there are connectors marked,from left, blue, green and red. Detach those from the old board,and mark the wires so that you may connect the correct the wires to the new board. You then unscrew the only screw connecting the board to the TV,and unhook the board from the TV. Hook the new board to the hooks which held the old board, and screw the lone screw to the board. Plug the gray cables from the new board to the connectors where the gray cables from the old board were,and do so for the blue cables. Connect the multicolored cables to the blue, green and red, just as was done on the old board. Reattach the cover and test the TV. Please do not replace the two STK ICs only. When I removed my old board, I realized that there was a burn mark, where the ICs were, but maybe it was a fuse.You may replace the ICs only to discover that it was another problem.Good luck, and I wish you all the best in the repairs. I just saved about$100 for a repairman just to show up.
Posted on Dec 11, 2008
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Tv turns off while watching it stays off a couple
Sharp 60" DLP 1080i , while watching cable, the show blinks off and on. but if we play video games or watch DVD's it works fine. what is wrong?
Jun 23, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
No power, lost power while watching tv
after picture is lost, does the screen remain lighting?
Jan 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
Great sound no picture
When I turn my tv on there is one certain channel that goes black after watching less than 5 minutes. this might be due to electronic tuner or loose contact in that particular section. 100% problem will be solved thanks
Sep 09, 2007 | Sanyo DS24205 24" TV
Convergence setup menu gone
No rest on this model other than unplugging to let it return to factory default. If your a tech .. Check R19722 and R19703 for open. Both 750 K. these open make the convergence menu to be gone.
Jul 13, 2006 | RCA P52929 52" Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
