Question about AT&T LG CU720 Cell Phone - Silver
Screen display not working properly
Phone is only 4 months old. Screen is displaying varying lines and colors - nothing is legible on the screen. Incoming calls do not display caller information - no menu options are legible. What could have caused this and how can this be fixed?
  • kakashi919 Nov 14, 2008
    same problem here...the screen has a line in the middle and i cant see anything
Not a PERFECT solution, but it's a slight one
i have the same problem. i go through it everyday.
but when my phone does it. i either hold down the joystick, or the delete button, and it puts away the lines for a slight bit. be careful when sliding it down though, sliding it down hard can also cause the lines to show up.
Posted on Apr 15, 2009
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
Lines in the display screen
This is not the fault with remote control.
Aug 26, 2012 | Logitech Harmony 1000 Advanced Universal...
The display of my phone is working but for last 2 days , there are 3 -4 horizontal lines . i dnt knw the reason . i evn tried factory settings but of no use . please provide me with necessary remedy for...
Hi, possible causes for horizontal line on screen are,
Phone Screen problem and,
The flex of a phone.
When a screen displays horizontal lines on the screen, is when screen of the phone is getting damaged due to phone falling on the ground,or hitting phone on an object can cause horizontal line on a screen.
Solution to this problem is to replace the screen of the phone.
The flex of the phone can also cause horizontal lines on a screen. The flex is a thread like object inside the phone that makes the phone to function properly in terms of the display..
When the flex is getting damaged, it can cause such horizontal line on the screen display.
Solution for this problem,is to replace the flex.
Note : flex can be found only on slide phones.
Thanks for using fixya........
Sep 15, 2010 | Nokia BH500 Bluetooth Headset For N95 8GB...
HTC herm200 phone not working properly.. :(
its just the display problem u can just replace the display and it will be done!
Jul 15, 2010 | HTC Cell Phones
Phone seems to work, but has a blank screen
i think its display problem.. check the display once... or take a new dispaly
Nov 20, 2009 | Nokia 6300 Cellular Phone
White area in LCD screen with colored vertical lines
LCD needs to be replaced.
Common problemcalled "Tab separation".
Nov 24, 2008 | Acer Aspire 8920-6671 Notebook
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Blue shading problem
2 months old? I'd call the dealer..it's under warentee. You have a problem that will not get better.
Jul 14, 2007 | Samsung PS42P4AX 42 in. HD-Ready Plasma...
AT&T LG CU720 Cell Phone - Silver Logo
208 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
