Recently, everytime I attempt to burn files to dvd, the computer comes up with an error message. Sometimes it is almost straight away and sometimes when it is a fair way through burning. There are different messages each time. Illegal write errors re: location?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Slow the recording speed down some more, sometimes your processor can not keep up basically.
Posted on Nov 13, 2008
I am having issues burning dvd or blue ray from my mac with adobe premiere elements. It is an external burner connected via USB works fine with final cut but has error message with elements. Says " device...
Try burning an iso image file instead from the program, then you can use the built in mac software to burn that disk image file to a disc. Sometimes in video editing there is a problem with the process of compiling the video to a disk. Try a simple very short project with a dvd-rw (reusable) disc to see if it still gives the error.
Apr 11, 2014 | ASUS Computers & Internet
When attempting to back up a file to cd error
make sure your disc is a rewritable CDRW or DVRW
Jun 27, 2009 | NEC ND-6500A DVD±RW Dual Layer Burner
Cucusoft avi to dvd converter pro 7.0 everytime I use it crashes
check your software....also sometimes you have to disable other burning software you have, seems the software is fighting among themselves, antivirus sometimes interferes, check Burnworld .com
Mar 06, 2010 | Lite On Cucusoft MPEG/AVI t
My compaq laptop will not allow me to burn cds using windows media player. it worked before but now when i try to make a burn list it says connect a burner and restart player. What can i do to fix this?
It might be that your Laptop is not seeing the CD drive in the Device manager this happens sometimes the best quick fix is to use Doug Knox excellent tool to restore the drives in Device manager.
http://rapidshare.com/files/261550163/XP_CD-DVD-Fix.zip
this will re-establish the drives within the system if they are missing this sometimes happens with CD burning applications and this will fix it for you .
LOL
Sep 27, 2009 | Compaq Presario CQ60-220US PC Laptop
DOES NOT BURN DVD; AT END OF BURN "ERROR" MESSAGE W/ NO INFO
I see that you are using a DVD+R disc...Some drives can only do + or -. Have you tried using a DVD-R disc? You could also check and see if there is a firmware update from the NEC website.
Sep 05, 2009 | NEC ND-6500A DVD±RW Dual Layer Burner
Computer doesn't seem to recognise it - can't open files or burn
This is a pure problem with your DVD drive. try removing teh cable and reinserting it.
May 02, 2009 | Computers & Internet
Error Message 'F:\ setup.exe is not a valid win32 application'
This issue can be caused by any of the below possibilities.
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Mar 18, 2009 | Computers & Internet
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
DVD Burning Problem
To reinstall the driver RIGHT Click on My Computer - select Properties - select Device Manager - RIGHT Click the DVD listing - select Update Driver (have your disk handy).
Good luck.
Apr 19, 2008 | NEC ND-2500A DVD±RW Burner
System restore problem
The system restore is blocked by a virus which causes problems to computers and confuses the system restore utility... Even if you have a super anti-virus... sometimes a new virus is the culprit. Or sometimes when you mistakenly allowed or ignored the warning message of your anti-virus.
Copy all your files to another harddrive or to another partition if you have. Or burn them to a CD/DVD
Then reinstall your computer.
Good luck.
Jan 27, 2008 | Computers & Internet
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
