2003 kia optima is overheating. Changed tyhermostat. Now there is no water in the lower radiator hose after running it. Could it be a clogged radiator? I have never seen a thermostat that is in the lower hose??? Which direction does the water flow?
I'm not familiar with your model. Old school here... The water is pumped from the engine block at the water pump, into the bottom hose of the radiator. The top radiator hose is the water supply to the engine, with the thermostat housing at the end of that hose, mounted to the engine. Check and see if your hoses are routed correctly and if you have coolant in your radiator.
Hope this helps. Good luck!
My eMachine T5026 computer was sitting idle for over 24 hrs. When I wanted to use it I noticed toe...
(More)
My eMachine T5026 computer was sitting idle for over 24 hrs. When I wanted to use it I noticed toe light around the on off switch was not lit. I thought someone had turned it off, but when I pushed the button to turn it on I could hear what sounded like a fan trying to start up but but wouldn't. I unpluged the power cord and waited a few minutes then replugged the cord. Now the computer won't do anything. No sound no lights, so I replaced the power supply, but still no success. Any suggestions?
I have a FMI, GL-4000e fireplace that has a hard time starting, but once it does it will burn for...
(More)
I have a FMI, GL-4000e fireplace that has a hard time starting, but once it does it will burn for abour 10 - 15 minutes then shut down and automatically restart. The shut down and restart process continues about every 5 minutes. Any help here would be appreciated.
