Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
Ram won't come back up ge trash compactor
Motor working but ram won't come back up is a shear pin possible problem
    Sergeant:
    Champion:
  • 251 Answers
Yes contact ge about the problem
Posted on Nov 15, 2008
I have a ge monogram trash compactor the ram is stuck in down position, how can we raise the ram?
Start your investigation by removing the bottom plate. There should be a belt or chain going around 3 gears. Mine has 2 metal and one plastic. The 2 metal ones are on the ends of the rods that the ram runs up and down on. The plastic one is on top of a big speed reduction gear that is turned by the motor gear. Don't pinch your fingers but see if you can turn the big gear by hand. All gears should turn. If not check each gear for broken teeth, or bad bearing & races under the 2 rod gears.
Be sure to check t
he threaded hard plastic nut that drives the screw that powers the scissors up and down. This is the part that usually fails.
Nov 24, 2012 | GE Profile GCG1580LSS 15" Built-In Trash...
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
GE trash compactor ZCG3100BVV-02 won't start. I out a new on/off switch and it still will not start
Most likely a ram position switch but could also be a bad motor. process of elimination will lead to the faulty component...Eric
Sep 12, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile compactor
Here is an assembly drawing of your compactor.. Please note item # 102 ( direction switch) ..That may be affecting the perfomance of your motor or your motor may have a dead spot on the windings.. Here is a link to a website for parts that coincide with this drawing.. There isn't an awful lot to a compactor in terms of hardware so good luck.. Hope this helps..
Here's the link for parts... http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
Aug 19, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Sure is... The motor drives a ram up and down to compact your trash... Like most drive systems.. it needs to find a refrence position near the top of the stroke.. that position is normally sensed by a switch.. so it is possible your motor is bad or.. it is also possible your top sense switch is bad too.. For $400.. the GE tech should come out and stomp on your trash until it is compressed.... In either case.. if you are handy.. you may be able to open the compactor up ( with power unplugged) and check the position of the ram.. if it is near the top.. you may be ableto reposition it down a little then try cycling it.. It may buzz if the motor is bad ( windings shot) or it may work OK.. if it does and the problem comes back after you cycle it.. there is a good chance the top sense switch is bad or the windings in th emotor bad too.. Hope that helps...
Aug 16, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash compactor problem
I have had this problem on my GE Monogram. The 'smasher' is near the bottom and does not move anymore, even though the motor is working.
What I did was to get a crowbar that would fit through the crack and hook the underneath side of the bottom plate. You also have to hold the switch so the motor runs with the door open and pull up on the plate until the drawer can be slide out. The trunnion nut (a plastic nut) was cracked. I replaced it 3 years ago, and it just cracked again. They now make it out of metal, so maybe it will last longer. Ordered it from appliancepartspros.com.
Jan 11, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
444 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
