Question about HP Officejet 5610 All-In-One InkJet Printer
Printer will not power on.
Got home from work and notice the printer lights blinking SHUT Off, so I shut off now it will not turn on. I did check the power adapter and the outlet. I did notice the adapter does not warm up at all. Not sure what happen the printer is 6mos old and have not had any problems prior to this.
Pls help
Margie
HP officejet L7590 all in one.
Thk you..
If its not that old take the powerpack back and get a new one!
If that fails, box it up and take it back with your receipt, afterall why waste your precious time if its in cover period x
Posted on Nov 13, 2008
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Sep 19, 2014 | Brother HL Office Equipment & Supplies
Yellow light blinking
Typically, printers will blink a yellow light to indicate a communication problem between the printer and the computer.
1. Shut your printer and computer completely down.
2. Check connections to printer
3. Follow connected printer cables to the related computer port.
4. Check connections to computer
5. Turn the computer on and let it boot up
6. Turn your printer on.
Jan 20, 2013 | Office Equipment & Supplies
My computer doesn't send picture to be printed to my hp photosmart 8450. I have Windows Vista and it worked before. Now why does it show an error in the printer info and also, this printer is set as...
If there is something wrong with the printer, you should get a error message describing the error.
Does the printer have a blinking orange light after you give the print command? Then there is an error in the printer. If you have documents in the print queue, delete them. Remove the printer cable. Shut the printer down, shut the computer down. Reconnect the cable and turn everything on again.
If there is still a problem there might be something wrong with your printer.
If you don't have a blinking light after the print command on the printer, then try changing the printer cable. If not working, try another USB port. If still not working, reinstall the printer.
Sep 21, 2010 | Dell Office Equipment & Supplies
My Deskjet 5440 will not even respond to being plugged in to power or USB. Just a solid green light. Like it's frozen. Computer will not even notice it's plugged in.
shut down the pc, shut down the printer.
power it back on and the pc.
if still does not detect, do the following
on the desktop chose My Computer/right click/System Properties/Hardware Tab/Device Manager/go to Universal Serial Bus Ctl (this will be at the last of the list)/ + click plus sign on the left to expand /go to each and check if all devices are working properly by right clicking go to properties, then go to USB root hub (if there are more than 1 then go to each one by one and do the foll)
go to 1st USB root hub, right click, properties, power management tab, remove the tickmark on the box that says "Allow the computer to turn off power to save power"
Do this for all the USB root hubs listed there.
Shut down PC and restart. Check if now the printer is being detected.
Dec 07, 2009 | HP Deskjet 5440 InkJet Photo Printer
Hp d1460 wont print test page,wont print from wordpad in windows xp home
1.Turn the printer on
2.Press and Hold down the Power Button.
3. While Holding Down the Power Button, open and Shut the lid of the printer four times.
4.Release the Power button. The self-test prints.
Nov 18, 2009 | HP DeskJet D1460 InkJet Printer
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Problem starts with "paper jam" messager. Can not shut down as light keeps blinking and "shutting down" message is on screen.
hi!!!! in your case,try to unplug the power of your printer and check the material that stock inside the printer that can cause the printer paper jam and after you check to plug it back.It is normal when the printer is blinking when the printer is paper jam because that is the error when your printer is paper jam.
May 11, 2009 | Office Equipment & Supplies
Two red lights blinking, power light off
you need to reset eeprom using the software
http://www.yoreparo.com/foros/download.php?id=2057
today i fix a epson r200 with that
Mar 28, 2008 | Epson Stylus Photo R200 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
