Question about Pentax Optio S50 Digital Camera
SD card will not stay in camera
The SD card will not stay in the camera. It should click into place so I can shut the card cover and it is impossible to do that. The card works when I can manage to hold the card in and quickly shut the cover, but as I said that has gotten just about impossible. Is this likely a card problem or a camera malfunction and if it is where should I send it to be fixed?
  • bbclinda Nov 19, 2008
    I have a Pentax k100 digital SLR. I have the same problem, it started when my SD card case split. I tried a new sd card but it did not fix the problem.
  • 641 Answers
Try to use another SD card in your camera. If the phenomena is still exist, the problem is with your camera (in most of the cases it is a broken plastic part of card's "house").
Posted on Jul 29, 2007
Why does it say that there is no external storage for my camera? It won't let me use the camera.
there might b sd card mounting problem.. try using ur sd card in any other device and see if it works.. if it does not, there is little u can do. apps are avaiable on android market to resolve sd card problems and revover data. however, if it works fine in other device and only shows problem wid the cam, it might b that the device does not support the sd card, ie. the storage capacity is too large to be mounted by the device-.
Dec 04, 2014 | Cameras
My camera first would not recognize the memory card that was in there and later the memory card would not click and stay in place.
Are you sure you are using the correct memory stick?
Most cameras use SD cards, but Sony uses Memory stick Duo pro.
Make sure you have the right memory, because not all Memory sticks are compatible and not all can be user for both, stills and video.
If you have the right card, make sure you only put it in like described in the manual. If you try to put it in, the wrong way around, toy could damage the camera. (most likely you will bend the contact points inside the memory card holder) and if you already did, it could be almost impossible to get that right, without sending in the camera to a Sony service centre.
For memory card use, see page 276 and 277 of the (english) manual. The manual can be found online.
Jan 21, 2014 | Sony Cyber-Shot DSC-HX9V Digital Camera
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
Nikon D40 - The memory card will not stay in. If I put it in and close the door, it still must not "click in" far enough because the camera won't recognize it. The only way it works is if you...
hi Jfurbees.
this is all i could think off just to help you out in till you can get it fixed.
I don't have a permanent fix, but one thing that works is folding up a small piece of paper and holding it over the memory card while closing the cover so that the cover pushes on the paper which holds the memory card in place automatically when the cover is closed. You just have to experiment to get the folded paper the right size and thickness. Again, its not a fix, but it has worked for me.
I shone a really bright light into the SD slot and sure enough, behind the gold springs at the bottom of the card slot, was a tiny black sliver of plastic that moved slightly when I tipped the camera. About 3mm long.
I removed the camera battery. Then I got a big long sewing needle, and with some very gentle manouvering, so as not to scratch anything inside the camera's SD slot, it fell out just when I was about to give up.
After I'd got the plastic sliver out, I trimmed the splintered edge of the SD card and put it back in
this is not to say it will work for you but give it a try but this will be at your own risk.
Dec 01, 2017 | Nikon D40 Digital Camera with G-II 18-55mm...
When i put a new memory card in, the camera reads "memory card needs formatting", but when i click format, it does nothing
While some Easyshare cameras will use SDHC cards, the documentation for the Z740 states that it uses MMC and SD cards.
Try using an SD card. If that works, then stay with SD cards. If that doesn't, then there's something else wrong.
Sep 04, 2010 | Kodak EasyShare Z740 Digital Camera
Memory card won't stay in the slot, won't read.
service camera at Nikon. mechanical SD card lock failure
Nov 24, 2017 | Nikon Coolpix S210 Digital Camera
I have the same player, you must insert the mem card until it clicks into place, this locks it in the player and should take care of the prob. Just keep pushing til you feel the click.
May 07, 2009 | RCA Pearl TH1102 MP3 Player
Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Mar 11, 2009 | Nikon D60 Digital Camera
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Pentax Optio S50 Digital Camera Logo
63 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
