Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Fidgedaire dishwasher leaking from bottom of door
Replaced door sweep and still leaking
  • 734 Answers
You can try and make the door close tighter. Open the door, and there should be 2 screws that hold the other side of the latch. Loosen the two screws and push the latch back towards the back of the tub. Tighten and see if that takes care of the problem. That is where I usually start when leaking from the tub.
Posted on Dec 02, 2008
Rain water in passenger side floor board
It could be the window sweep set is allowing water in or the door seal around the inside of the door jam and another over look problem is that the heating core is leaking coolant in to the vehicles cabin but the leak would be close to the dash if this is the case
Sep 28, 2016 | 2003 Nissan 350Z
Lgservice com
Weather strip on top and bot sides(jams) and a weather sweep on the bottom.
Jun 23, 2014 | Televison & Video
I need to replace door sweep for sa12025-01 maax
need to replace door sweep on maxx shower
Oct 22, 2013 | Plumbing
Power comes on for two seconds then goes off. Trouble code is 21. Is this worth fixing?
The X-Ray Protect circuit monitors:
* Excessive High Voltage
* Excess CRT Beam Current
* Excess HV Circuit Current
The X-Ray line is normally High. If any of the monitored sources exceeds its' specific reference, the X-Ray line is pulled Low, shutting Off the TV. If X-Ray protect shuts the TV Off, pressing the Power button will turn the TV back On ( it will shut Off again if the problem still exist).
Possible Problems: Power Supply Fault, Sweep Circuit Problem, Doubler Board Fault or a leaking CRT. You may have bad capacitors in the power supply or the sweep power supply.
Check for CRT leaking, few drops of clear light oil. If this is leaking the fix is costly and not worth fixing.
Inspect for puffy capacitors on the power supply and sweep circuit boards, if you can solder replacing capacitors is cheap, middle pricing for replacing power supply or circuit boards.
Feb 28, 2011 | Mitsubishi Televison & Video
Ice maker hanges up ice forms on blades
Hi and welcome to FixYa. I am Kelly.
Usually when ice (teardrops) form on the sweep blades it can be caused by a couple of things.
1. A dirty freezer door seal
2. A torn freezer door seal
3. Separation in the freezer door.
4, Calcium build up on the sweep blades.
Give the door seal a serious look for dirt and tears.
If the door seal looks ok and is clean then...
Wash the icemaker sweep blades with a mixture of vinegar and water. Give the freezer door some attention with that same mixture. Oils from hands or food can prevent a good seal on the freezer door. Just make sure you clean the icemaker sweep blades FIrst...
Do not use a new scotch brite pad on the sweep blades. USE an OLD one.... scratches on sweep baldes invite condensation when the door is opened.
Make sure to toss the next few cycles of ice cubes.
Doing the above should stop the ice build up on the sweep blades unless you have folks or visitors in the home that love holding the freezer door open for longer than normal.
Thanks for using FixYa.
Kelly
Feb 09, 2010 | Refrigerators
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
1995 Olds Ceria
Try steel rubber products, i believe they have an on line catalog.
May 09, 2009 | 1995 Oldsmobile Cutlass Ciera
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
177 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
