Question about Pioneer DEH-P3500 CD Player
Buttons do not work on face plate but CD and volume dial do
All I can do is put in a CD and let it play through, I cannot switch tracks or switch to radio, all I can do is adjust the volume. If I take the CD out the head unit powers off, anyone had this problem?
  • 2 more comments
  • EgoTrippin Dec 12, 2008
    Yes, the same thing happened to me recently. How old is yours? I think I got mine in early 2005. It sounds like Pioneer rigs these things to break down after 3-4 years.
  • fordblue300 Dec 18, 2008
    No, this happened instantly. As if the power or a connection to all the buttons all at once was severed. the only thing that works is the volume but that is a rheostat and it must not be tied in with the rest of the controls.
  • sweetpixy14 Dec 26, 2008
    My unit is pretty new. Are you sure that's the only solution? I had heard there was a security code that needs to be put in in order to unlock the system, but I don't know what the code is.
  • Anonymous Mar 10, 2009
    exactly the same issue. the only way to turn it on is to put a cd in and you can't even switch tracks. only the volume. i tried pulling the fuse, but nothing works. i want to hear more about this code thing though, sounds promising
I had the exact same problem and after searching and googling, I figured out that maybe the buttons were jammed in the the D pad part where you change the songs and stuff.. so I took it and fiddled with thebuttons and still no go, so then I pulled a Fonz and punched it because I was angry and it worked so it shook something loose,so I think it's locking up because somewhere in the cursor part is jammed and needs to be undone
Posted on Jun 15, 2009
    Sergeant:
    Champion:
  • 247 Answers
The problem your having is from the buttons wearing out over time and the only way to fix the problem is to replace the face plate or the whole radio.
Posted on Dec 16, 2008
  • Thomas Dec 19, 2008
    is the face plate detachable or not?
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
Jul 09, 2012 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Turns on but won't turn off. All of the buttons on the faceplate do not work but it is lit up. Can only listen to the one station when I turn it on. Will play CDs but no way of changing the tracks. To...
It sounds to me like you may have a bad volume control switch. Unless you are good at unsoldering and soldering, I would suggest you have it repaired by a professional. Either that or see if you can find a replacement face at a pawnshop or something like that.
Sep 08, 2011 | Panasonic CQ-DF402U CD Player
Hi. I have a blaunpunkt CD34 stereo in my car and it seems to be locked into one radio station as no buttons work accept the volume. It will allow me to play a cd but I can only adjust the volume on this...
is your radio come with remote control? you can confirm other function with remote control, if still working, then most likely the face plate connector connection is loose, you have to dismantle the radio out from car, and then open out the side screw secure the face plate to radio body, Unplug the face plate out from body and re assemble back to test.
Aug 20, 2011 | Blaupunkt Car Audio & Video
I've had my Sony Xplod CDX S2010 Radio/CD player in my Jeep for years and it has all of a sudden locked up on me. The CD player will play and eject CDs, however it doesn't allow me to adjust volume or skip...
i'm not sure if there is a flexible cable that goes from the face to the motherboard. if there is, that could be the problem. it could also be a bad switch.
Aug 25, 2010 | Sony CDX-S2010 CD Player
Another one with Faceplate buttons not working?
The capacitors in these plates tend to burn out quickly for being so hot and lack of air cooling circulation. You can test all connection pins on the deck and faceplate with an ohmmeter in ohm setting to see which pins is not sending 25-30 ohms or 5 volts of power
Oct 23, 2009 | Pioneer DEH-P3500 CD Player
Clock set
To set the time press and hold the select button in the centre of the volume dial until the word demo appears on the screen. From here you can change the time by pressing the next track >>I button to select clock h. Use the use the volume dial to select the hour. Use the next track button >>I to select clock m and use volume dial to set the minute. This same procedure can be used to change the dimmer on/off, demo on/off and the amp gain. Have a play around. Hope thjis helped.
Jun 29, 2008 | JVC AM FM CD DET FACE CAR STEREO
CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Jun 05, 2008 | Sony CDX-S2000 CD Player
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
Cd pioneer dehp350
check for a stuck button on the face. Thats what happened to mine. Nothing on the face worked... remote wouldn't work...started pushing buttons untill one "popped" and then everything was fine.
Dec 31, 2007 | Pioneer DEH-P3500 CD Player
Alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Jun 08, 2007 | Alpine CDA-9855 CD Player
Pioneer DEH-P3500 CD Player Logo
409 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
